As oldcorollas said, the base of the windscreen is a high pressure area - not really a good spot for a heat extraction vent - it will work (as there is high pressure hot air underneath the bonnet) but not as well as it could elsewhere. The lowest pressure area is usually about 1/3 of the way up from the front of the bonnet.Originally Posted by AndyTTR
I doubt the under-trays will work particularly well in all cases, simply because it will add resistance to the path of the air flow through the radiator... if you add resistance to that path, then you'll find the air will simply try to go around the radiator altogether.Originally Posted by petespipes
AndyTTR -> although it may seem like the intake manifold gets 'really hot' i doubt that it will cause a *huge* increase in intake temperature. You could try coating the manifold, and you could also try putting an insulating material between the manifold and the rocker covers (as i'm assuming the manifold is some kind of aluminium, which is a fan-diddly-tastic heat conductor from what i recall).
whatthe? -> The front of the bonnet has quite high air pressure when the car is moving, even through a very small air opening it won't have much trouble breathing.
