Results 16 to 22 of 22
Thread: Broken bolt removal services
    Default Re: Broken bolt removal services
    Quote Originally Posted by love ke70
    all well and good til the easy out snaps...
    Quoted for the truth.
    If yo u snap the easy out, you wont be able to dril it out again. Its the hardest metal known to man!
    Use the easy out as a last resort.
    Quote Originally Posted by big_zop
    if its out 10mm, try some vice grips (that is assuming you have the space to get at them).
    Failing that, you could probably tack on a bolt head and use a socket normally.
    or weld on a 30cm bar, so you can twist it out directly...
    10mm should be plenty for a pair of good quality vice grips
    i am a Backyard Mechanic WiLo's Avatar
    it was closer to 5mm and is now down to about 1mm because the bolt was cracking, but ive managed to chip and drill away enough at the easy out that im going to try with a smaller one and some of the loctite freezing stuff people have spoken about.
    edit: nevermind its completely f****d now. given me a good excuse to fit a 1275 although it will leave me with 6 months to fit some discs on the front or find a lenient rego inspector
    milk and juice come in 2L, The cheapest wines come in 5L, the finest vodka comes in 1L
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    ohh what happened?
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    nooooo, easy out broke??
    time to call bolt doctor and make him work for his money
    Junior Member Grease Monkey Yojimbo's Avatar
    Nov 2007
    I need to get a few helicoils put in to repair threads for my ex. manifold studs.
    I know these are generally pretty easy to do, but beacuse of the placement ( need 90 deg drill) I think I will get someone to do it.
    Any idea of good people to do it in Newcastle, and any idea what it would cost?
    8 - 10 buggered threads.
    Matt
    yeah easy out broke, and being in the shitty mood i was in i figured either try drill it out or engine comes out anyway, instead of buying the suzuki GTi im going to look at tomorrow im going to blow the money ona reco motor instead, jsut have to decide between a sports 1100 which i can fit legally without doing a disc conversion on the front or fit a 1275 and try find a lenient pink slip person when rego is due
    By The Witzl in forum FAQ
  2. Bolt FAQ
    By dogeatdog01 in forum Tech and Conversions
    Last Post: 18-02-2008, 03:52 PM
  3. 2jz crank pulley bolt removal
    By Draven in forum Tech and Conversions
    Last Post: 02-07-2006, 04:01 PM
