Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: Reset ecu to gain performance?
    Default Re: Reset ecu to gain performance?
    cooter... it takes a few days to relearn your aggressive style too. By which time your motor is probably fried. Just something to consider before going and rooting your tune before an event.
    GT4 Freak, and Conversion King Squid's Avatar
    I talked to the guys at Neal Bates/TRD about this a while ago. It does make the tiniest difference, but not worth doing mostly just a placebo effect.
    If someone will sponsor a second dyno run for me on sunday I will test the theories...
    ST185 GrpA #116
    ST165 GT4 Project Car - Soon with v6 goodness.
    The glass is neither half empty nor half full, rather the glass is twice as big as it needs to be.
    how does "aggressive driving" affect what the motor needs in terms of fuel and spark?
    it would affect auto shifting times/rpm, but the engine needs certain fuel and spark to meet emissions goals and power goals..
    and again, how does the ECU know when it is safe to adjust fuel or spark if it has little or no feedback?
    It makes it "Fully Sik Uleh"
    I personally agree that this idea is a load of shit
    It keeps coming up again and again on the Soarer forums... fact is you can drive your car as hard as you want all day, reset it 50 million times and when you chuck it on a dyno you'll still get sub 11:1 AFRs and ultra conservative timing
    OC is correct here.
    The ECU will correct CRUISE maps for fuel, and ignition timing WILL be retarded if knock is detected.
    If the ECU were to be left to do what it wanted with timing retard and advance, then your car would not just have an oxygen sensor, but a whole 5 band gas analyser. As if the ECU just increases timing for great power, then emmisions in NxOx emmisions, goes through the roof.
    There is a long term table, which is stored when the engine is switched off, and a short term, which resets under each time the engine is restarted.
    If the engine has a long term issue, resetting the ECU can "remove" the retardation etc, until the ECU learns there is a problem again.
    Basically, it's only really worth resetting IF your ECU has logged a fault.
    When I reset my Commo ECU I got nearly double the power when I planted it off the mark... Purely for the fact the ECU had logged a fault, retarded ignition timing, and locked the auto gearbox in 2nd gear, and 3rd gear only.
    Upon reset, I had 1st gear, and "normal" ign timing. (Car had a major gearbox fault... )
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    AB
    Quote Originally Posted by Kyosho
    OC is correct here.
    i'll second (or would it be third) this.
    Quote Originally Posted by merc-blue
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
  8. #38
    Junior Member Domestic Engineer dandan's Avatar
    May 2006
    So if I was to take my 4age down to the race track for the day I would NOT be faster if I reset the ecu at the start of the day (after warming the car up) and doing a few hard laps?
    Damn, no free power.
    AW11, aus spec 1987
    What is the legality of sea food extender? I know you're not allowed to have a quick feast in a street car but am unsure of just the extender.
  9. #39
    Worth reading it's only short.
    Believing??
    http://www.autoblog.com/2006/10/17/c...TOKEN=25439153
  10. #40
    Can't believe this thread is still going (Post count +1)
  11. #41
    got 71? Grease Monkey cooter's Avatar
    wa
    yeah was just a thought. got aftermarket anyway so no frying. i hope lol
    Te71 Corolla Levin, Blacktop 20v
    Te71 Corolla Levin ex Rally Car 2tg.
    Te71 Corolla Hardtop 2dr Sedan, 2tg/3t waiting
    Ke70 Corolla 4dr Sedan
    Ae86 Corolla sprinter 4ac
    Corolla Feind
  1. GZE ECU Boost Cut?
    By SG-EE100 in forum Tech and Conversions
    Last Post: 15-04-2007, 12:24 PM
  2. O/D & A/C on for a 1JZTE ECU?
    By ZZT231 in forum Tech and Conversions
    Last Post: 12-06-2006, 01:29 PM
  3. ECU....all the difference
    By Alchemist in forum Tech and Conversions
    Last Post: 22-05-2006, 11:54 AM
  4. Braking performance, over time.
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 07-05-2006, 04:53 PM
  5. 7AFE performance options?
    By birdie in forum Tech and Conversions
    Last Post: 21-12-2005, 04:09 PM
