Results 1 to 2 of 2
Thread: ta22 reverse lights wiring
    Junior Member Grease Monkey imlach74's Avatar
    victoria
    Default ta22 reverse lights wiring
    changed my ta22 from auto to manual and dont know how to hook up the reverse lights....if got 2 wire off the gearbox and 4 wiring from the car.... i have no idea wat goes to wat because they were cut wen i took out the auto.
    can someone please help sort this out.
    2tg
    Default Re: ta22 reverse lights wiring
    The auto will have a neutral start switch along with the reverse lights. The 2 wires for the reverse lights are Red with Blue trace, if you get a multimeter test that they close the circuit when reverse is selected and the lights should work once you hook it up. Power comes in one side from the fuse panel (tail fuse i believe), and then passes through the lights before being grounded.
    You will also need to bridge the neutral start sw as it is no longer needed.
  1. gtv TA22 wiring diagram wanted
    By 74gt in forum Tech and Conversions
    Last Post: 12-01-2007, 09:30 AM
  2. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 11:27 AM
  3. ta22 wiring diragram - Old Scanning
    By Classique71 in forum Tech and Conversions
    Last Post: 01-01-2006, 05:00 PM
