Ok, fair enough, didnt' know it wasn't a 22's booster.
The booster is definitely NOT a TA22 item. The TA22 items are 2 bolt, and smaller diameter and thicker. Its either TA23, RA23 or RA28. The steering box can be re-sealed and re-tightened for re-use, unless it is seriously stuffed (havent seen one that is unrepairable yet).
Aisin make the stock carbies for toyotas, except for side draught mikunis. So i dare say the carby you have is a paperweight. A better carb is either the 180 holley, or the 32/36 weber.
item B looks like the gear selector out of the gen1 gearbox, then again perhaps not.
98 3rz-fe Hilux 4x4
97 Hiace AWD Super Custom 1kz turbo diesel (sold)
87 MA70 w/ 1JZ-GTE Manual Conversion GT (moss growing on roof deteriorating away but open to offers)
All of these parts havnt seen light for about 10 years lol
urantia, i should neg rep you for that !!It doesnt look anything like a gear shifter, look at the pitman arm with the ball joint with castle nut on the end of it.. dont look like a gear shifter at all
dam upon closer inspection i think i could be wrong
(from a distance, or thru a fuzzy 14" crt, it does look like it could of been a part of the st162 gearbox where the two gear box selector cables connect to)
98 3rz-fe Hilux 4x4
That is the top part of the 18R air con bracket, there is a second cast bottom piece that is missing.
bugger so im down 1 part? is there anything else that is interchangable for that bracket?
spectre, if you want an 18R air con pump and bracket, either myself of brett_celicacoupe will have one. I think i even have the wiring for one too somewhere.
heres another?
First item is the air con adjuster. The RPM switch tells the air con to turn off at idle, and the hot cold switch will modify the gas pressure, and therefore the temperature of the air con. Second item im not too sure, but it looks like the light dimmer switch.
