Results 1 to 15 of 26
Thread: Identify these Celica Parts Please!
    Default Identify these Celica Parts Please!
    Have these Celica parts... and have no idea what they are! Please help me!
    Item A:
    Item B
    Item C (a fuel pump?)
    Item D (a heater core?)
    Item E
    Item F (booster?)
    Item G (air con?)
    all help appreciated!
    Bryce
    My Missus is a Domestic Engineer BradW's Avatar
    Default Re: Identify these Celica Parts Please!
    Item A: Idler pulley, most likely for air con judging by your other items.
    Item B: Possibly a steering box, not sure though.
    Item C: Receiver/ drier for air con.
    Item D: Evaporator core for air con.
    Item E: Fan motor (interior fan).
    Item F: Brake booster.
    Item G: A/C compressor.
    Brad
    Old Corollas never die...
    My KE30
    Item A- air conditioner belt tensioner idler pulley
    Item B- steering box, either Gen 1(TA22 through RA28) or Gen 2(RA40)
    Item C- Air conditioner reciever/dryer
    Item D- Air con under dash unit, TA23 through RA40.
    Item E- Heater blower fan.
    Item F- Brake booster. If it has 2 bolts where the Master Cyl bolts up, it is RA40, if it has 4 bolts, its TA23 through RA28
    Item G- Air con pump and bracket, either 2T or 18R
    If you tell us what model car they came from, then that would help, but i would say either TA23, RA23, RA28 or RA40, not TA22
    damn, you beat me to it brad... but hey, my post had more info
    Mad****** Grease Monkey FASTFOO's Avatar
    vic
    Bradw is right and B is a steering box.
    I Would say they are from an RA40 and the shoe in A is a size 9
    but now I am starting to guess.
    MATT.
    Less info means quicker post .
    Brad
    My KE30
    Im actually leaning toward gen 1 fastfoo, cause the air con i had on my 78 RA40 was different to that one, and the later RA40s seemed to be the same as what i had... so i would probably even say TA23, as the air con mounting bracket lends itself toward a different block than the 18R. The number of studs on the face of the brake booster will tell us if its gen 1 or 2.
    Unbiased Grease Monkey Earlyrolla's Avatar
    Had a quick look at the 18RG, 18R and 2T air compressor brackets and they all looked different to the one pictured. But it is quite possible to have a different bracket if the compressor type used was different.
    Maybe a pic of the bracket from the other side could clear that one up?
    AC idler-pulley bracket looks upside down - but familiar to mine (18RC) that i've been looking at for the last hour or so (while working my crank trigger).
    the evap core is probably not RA40 as mine had foam on the edges of the outlet where it fed into the heater unit. It too is pictured upside down
    so another shot of... item G? apparently there for a ra23/28?
    i
    Yep, from the opposite side to get a better look at the cast bracket the air compressor is bolted to
    so assuming its the 1st gen bracket... ive got a complete aircon setup for a 18rc/g?
    you still need the condenser, looks kinda like a radiator. Oh, and its all gotta be wired and piped up.
    oh that thing that looks like a mini radiator? yeah ive got that too!
    heres that other shot:
    and the brake booster has 4 bolts so im assuming thats a 1st gen item?
    Also, how can i work out what type of carby ive got? I think its an original one but so far the only word ive found on it is "ASIAN" lol
    Yeah mate, the brake booster is definately from an RA23.. Probably also an RA28, and probably a ta22. They're pretty hardy little suckers, and despite their size they can be valuable. Don't throw it away.
    Plus, with that Steering box, that is a '23 steering box, if it's tight still it might be worth money too, so don't get rid of that one either. :-)
    Facebook | LinkedIn
  1. Toyota Model Codes Explained
    By wagonist in forum FAQ
    Last Post: 14-10-2005, 09:47 PM
