Surely someone has this info somewhere?
As the title suggests, I am having trouble finding any body wiring diagrams for JZX81's. I need to know where the Hydro Fan ECU and Variable Power Steer ECU get there signals from, and which wire/pin they go to.
Thanks in advance.
Progressive power steering only gets speed signal (same as SPD or SP1 on ECU and cruise control).
Hydro fan gets (from memory) radiator temperature sensor (2 wires, 1 of which also goes to diagnostic connector), power (2 wires), solenoid (2 wires), tacho input, triple pressure switch, air con input... and I think I'm forgetting something, there should be one more.
I'm in Brisbane right now so no access to notes. Remind me on the weekend.
I have (on loan) the JDM JZX81 wiring books that I intend to scan but traditionally it will be a few years before that happens.
Mos.
Thanks Mos. Will definitely be reminding you![]()
Mos send them down, i can scan them in![]()
I think the last one is IDL input ( idle pin from the tps) , again without notes.
Dave
Don't think so Takai.. I had to swear on my firstborn to be able to borrow them
Heh, ok fine then. Speaking of which how is that going? Made up the lost time from wiring Ed's car?
Back to civilisation yet Mos?
I used a 1UZ crown PPS computer in my 1JZ cressy, works fine. Hooked it up to the speed signal, earth, 12V, and 2 wires to the power steering rack solenoid.
244rwkw / 328hp @ 18psi
Do you remember which pins were what? Speed signal being SP1 I take it?
Mine was the one in the bottom middle of the pic, with BL written above it
Yeah SP1 if I remember correctly.
Bumping this thread back up.
I need to know what body plug has got the hydro fan wires in it?
-Sleeper 2J + R154 X83
-GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
anyone got the wiring diagram for this?
