Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: 2JZ-GTE Boosting Issues
    stunt dog Backyard Mechanic Esteban's Avatar
    wa
    Default Re: 2JZ-GTE Boosting Issues
    And now it is fixed! You want to link to that info, for the few blessed souls that actually use search... ?
    Checklist for VSVs:
    IACV (Inlet Air Control Valve): (Note: VSV 'E' goes from VSV to actuator)
    [OK] >VSV Hoses Correct ('E' [Closest to Plug] -> IACV)
    [OK] >VSV Resistance OK [OK: 38.5->44.5Ohms]
    [OK] >VSV Stops Pressure Up 'F' when OFF
    [OK] >VSV Allows pressure to IACV actuator via 'F' to 'E' when Energized
    [OK] >VSV Allows pressure from 'E' to 'Filter' when OFF
    [OK] >IACV Opens when pressure supplied to actuator
    [OK] >IACV actuator holds pressure (Does not leak)
    EGBV (Exhaust Gas Bypass Valve): (Note: VSV 'E' goes from VSV to actuator)
    [OK] >VSV Hoses Correct ('E' [Closest to Plug] -> EGBV)
    [OK] >VSV Allows pressure to EGBV actuator via 'F' to 'E' when Energized
    [OK] >EGBV Opens when pressure supplied to actuator
    [OK] >EGBV actuator holds pressure (Does not leak)
    WG (Waste Gate): (Note: VSV 'E' comes to VSV from actuator)
    [OK] >VSV Hoses Correct (Actuator -> 'E' [Closest to Plug])
    [OK] >VSV Resistance OK [OK: 22.0->26.0Ohms]
    [OK] >VSV Stops Pressure Up 'E' when OFF
    [OK] >VSV Allows pressure from actuator to inlet via 'E' to 'F' when Energized
    [OK] >WG Opens when pressure supplied to actuator
    [OK] >WG actuator holds pressure (Does not leak)
    BV (Bypass Valve / Prespool): (Note: VSV 'E' comes to VSV from actuator)
    [OK] >BV Opens when pressure supplied to actuator
    [OK] >BV actuator holds pressure (Does not leak)
    In regards to the other issue (Cutting out/fake rev cut) I went to a blitz ECU and the problem went away.
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 2JZ Water Pump onto 1JZ
  3. Exhuast Questions
    By Z2TT in forum Tech and Conversions
    Last Post: 10-12-2007, 06:45 PM
  4. 1jz to 2jz
  5. 1jz vs 2jz heads
