Results 16 to 30 of 31
Thread: KE35 Corolla Conversion 1GGTE or 4AGTE?
    My Missus is a Domestic Engineer BradW's Avatar
    Default Re: KE35 Corolla Conversion 1GGTE or 4AGTE?
    Check with an engineer before going ahead with the 3rz, that is if you want it legal. I believe the biggest na engine you can legally put in a KE3x in NSW is 2.6L and with forced induction it's 2L.
    3rz is 2.7L, correct?
    Brad
    Old Corollas never die...
    My KE30
    yep thats correct 3rz is a 2.7.
    My 4agte is plenty quick enough for a ke30 street car. Ask bananaman.
    But of corse if you want stacks of power go the 1g.
    Junior Member Grease Monkey Brad-KE35's Avatar
    Yeah true, it's just after I drove Emp's Corolla you get hooked on the 1G powah! but it's a lil too powerful for my liking! So 4A will be more than enough!
    I might pick your brains out Cuzzo about your 4AGTE! hehe.
    Brad
    1977 Toyota Corolla KE35 - Undergoing 4AGTE transplant.
    1994 Ford Falcon Pedovan - Rape Dungeon
    well, an NA 3RZ will have the (potential) torque and powahz of a 4A with 10-12psi of boost..... or a 1G/3S with 5psi boost..
    you can also fit ITB and have wonderful NA sound
    if you want boost, and you want 2L, a 3S seems hard to go by... 2L same as the 1G, smaller, easier to fit in bay, better weight distribution, still 4cyl, not that hard to convert to RWD, plenty of versions to choose from with up to about 195(?)kw and 325Nm torque from stock engine. add a few more pounds and 200kw at wheels is easy.
    200kw from 4A is doable, but then it becomes a whole lot less drivable and more likely to break
    i love the 1g, but in all realities, 4a is the logical choice.
    but if you use logic wouldnt you just buy something faster to begin with?
    so really, do what floats your boat, theres not too much more work one to the other, so i would go with what you want.
    handling will suffer with the 1g however, i never really had a drama with mine in the ke70
    hey guys been watchin and i was just wondering just how much the 1g 4a 3rz weigh (aprox) cause im weighing up wat 2 do wit my 36 and i was (and still am) keen on the 1g but would like a little more info plz
    Quote Originally Posted by Brad-KE35
    Brad
    the dude had a fuckin t70 on it though it must have been an animal once it came on, out of interest how much lag did it have? i just sold the t70 i was gunna put on my 1g, i went for the gt3076r instead
    how is the gt3076?
    when does it come on and what size housing are you using?
    cheers, andrew
    hasnt arrived yet, should get here in a day or two, then it goes to the exhaust shop and tuners
    ive gone with the 0.63 exhaust housing, so it should be reasonably responsive and provide at least 220rwkw
    Sillycar: The car itself was fantastic off boost plenty of torque and it was very drivable off boost, if you wanted boost you had to wait until around 5500rpm but then its nearly time to shift gears anyways! Was a weapon none the less, Josh and his old man really thought it over good.
    That turbo would seem more reasonable than a T-70!
    Brad
    haha ill add my bit to this one
    I would go 4agte personally, 4age's are cheap as chips to build as opposed to 1g's which suck to get parts for! a nice turbo on a 4ag would get my vote, having driven a couple of 4agte now they lay lack alittle bottom end but still more than enough for a ke35... also cuzzo's is a damn screamer, not much i would change if anything from his setup for a street/strip corolla
    as for the T70 on the 1g, it had some strong top end and not much could get around it on the open road
    KE38 - 2TG
    MS65 - 1UZ
    Jun 2006
    Has there been any progress on this?
    I just bought a 1jz setup for my KE30 so just interested how your going with it.
    yeah I have a 4A sitting in the bay now, money permitting, still getting things ordered etc.
    1JZ would be mental, although you can't get it rego'd.
    Brad
    or fit it in without chopping big holes in the firewall
    KE38 - 2TG
    MS65 - 1UZ
    word up emp.
  1. MA70 --> JZA70 Conversion
  2. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  3. Getting 4agte conversion done... where in perth shall I go?
    By AE101LEV in forum Tech and Conversions
    Last Post: 25-05-2006, 07:59 PM
