Results 16 to 30 of 48
Thread: Chassis Strengthening RA28?
    New Zealand
    Default Re: Chassis Strengthening RA28?
    Look at something this for the front chassis legs, very cheap and easy to do. I just made up cardboard templates and got them cut out from 3mm plate. Have also joined the front and rear chassis rails.
    Callum
    So tonights work consisted of........
    Re inforcing rear trailing arm mount whilst joining rear chassis up.
    Also welded some seems underneath around some joining rails.......
    Please people post up your advice/your own pictures so we can all get some idea's.
    Nice work.
    I was also thinking about running RHS from the factory rails across to the gearbox xmember mounts.
    I never did it though as it wouldnt help with chassis twist strength, and i wasnt sure what my gbox xmember will look like yet.
    It would be good added protection from Tbone accidents though.
    im enjoying this thread very much guys! as this is something im coming to realise now that i have very firm susp,
    how much weight all up do you recon youve added with the bracing?
    Yeah me to MWP. I like what 30psi 4agte has done to his gearbox x member, but until i get a 1jz and r154 i cant really do that!
    I reckon iv probably added around 20kg's to the weight of her. Weight really isnt much of an issue tho. Its going to be that of its head in the end it going to need a bit of weight!
    I'll be conducting the chassie front/rear joining over the next few weeks. Can anyone see an advantage to welding the box section directly to the existing rails, or what MWP has done and weld it to the 'area' that the rail finishes at is perfectly acceptable?
    Thanks
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Just weld in a full cage Joel
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Haha yeah well in this project i'm going to weld in my 1/2 cage as currently its only bolt in.
    Where the legs go in the corner of the rear foot well areas i'll box that section together with the side rail and the rail that goes across for the seat to bolt to.
    But that wont strengthen up anything in front of it. Not ready for a 6 point
    Quote Originally Posted by TurboRA28
    Thanks
    Joel
    I can't see any problems with welding the reinforcements in as MVP as done. It's still going to transfer and loads between the two members, and thats the aim of putting the bracing there.
    And as for welding the cage in, if you have plates on the underside where the cage bolts in, its probably better than welding becasue you spread the force over the area of the plate (providing your bolts are torqued properlly ) , whereas welding it in will concentrate the force more at the edge of the weld. Someone correct me if my thinking is wrong, but that my first impression.
    Like timbosaurus said, go the full cage but be sure to tie into the front and rear shock towers, and rear spring mounts for a really torsionally stiff chassis
    I like this thread too, I'd love a full cage, but like Joel will be going a 4 point weld in and then add some of this extra strength into the rails and in the front...
    jase
    JZA023
    I've got a six point alloy bolt-in, but don't run the front legs/intrusion bars most of the time. I'm thinking of getting it replicated in steel (for a bit more safety and CAMS compliance) and at the same time i'll consider welding in the rear half.
    It all depends on whether I can sell my proper race car.
    Current rides...
    2) White RA25ST
    Quote Originally Posted by timbosaurus
    Same plan here, weld in rear 4point and bolt in intrusion bars...
    Jase
    JZA023
    Has anyone done anything to brace/stiffen up the rear of the ra28's?
    Around the tail lights i'd be interested in hearing about.. I find the middle plastic section cracks often and last track day I ended up with enough flex for the tailgate to touch the body..
    Ideas on strengthening this area would be much appreciated
    If anyone has the location of the build thread (non toymods) of the blue RA28 with 1uz, twin cannons and the name "mini stang". I like what he has done when chassis strengthening.
    If i could find it id post it but i cannot . There are some good idea's in the build photo's of it. More so then my gayness chassis strengthening
  1. ra28 chassis dimensions
    By elbak67 in forum Tech and Conversions
    Last Post: 28-11-2007, 05:50 AM
