Results 1 to 5 of 5
Thread: RPM Signal
    Xistant
    Guest
    Default RPM Signal
    alrighty, i have a few to many things wanting rpm signal, so need some ideas on how to reduce the useage of the signal so all components are happy.
    -re should i pull pin out and solder all wires in @ the ecu?
    -splice into wire, solder heatshrink suffice?
    - bullet connectors and split signal
    - tap into wire.
    suggestions?
    Xistant
    Guest
    Default Re: RPM Signal
    anybody? 10char
    How ever you do it, should be decently soldered IMO.
    Signal wires start becoming a bitch if you get a bad join in a connector...
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    I had in my RPM signal once, RSM, Emanage and AVCR...with no problems. Just tapped once and soldered, then used plugs for the rest. Just the crimp red plugs...although get the better once where you crimp and can solder...
    Huh? reduce usage? what do you mean?
    Toyota uses a lot of junction connectors - where it's like a plug, but all the pins are shorted together. You could then plug as many or as few pins into it as you need; if you find there's too many things connected to it to the point where the signal is loaded up too much, it allows you to remove any number of pins.
    Mos.
  1. Toyota diganostic error code, where can i find them?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 19-03-2008, 12:42 PM
  2. Fault Codes
    By Duk in forum Tech and Conversions
    Last Post: 24-07-2007, 08:42 PM
  3. 4agze fault codes & diagnosis + Pulley
    By Poggy in forum Tech and Conversions
    Last Post: 01-05-2007, 10:11 AM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
