Results 1 to 9 of 9
Thread: Camira EFI Sensor ID Help Please?
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Default Camira EFI Sensor ID Help Please?
    Its for a custom Toyota build-up project in Malaysia. I unscrewed this from low down at the back of the inlet manifold of a 1.8L EFI Camira. Is it the inlet air temp sensor please?
    It has 3 wires coming off the 2 pin plug, and the numbers on the brass section read 06-85 / ELTH / 17-12 / 267023.
    It is amazing hard to find any wrecked EFI Camira anywhere in WA with its EFI loom and sensor's intact.
    Thanks.
    Default Re: Camira EFI Sensor ID Help Please?
    doesnt look like any camira intake air temp sensor ive ever seen...
    normally they have a grey end, with a little element in the middle.sorry i dont have a picture handy
    WA (Perth)
    Damn, OK - thanks for looking.
    I wonder what it could be then. It was not far away from where the throttle return spring wheel attached to the throttle body. There was no fuel line near it so I don't think it has anything to do with the cold start injector.
    RA23
    1G-GZE
    its not an idle up solenoid is it?? operating an internal air bypass?? have a look at the hole it came from, and see what goes in there, that will be your best bet.
    WA (Perth)
    Owen,
    Trusting my memory here as I picked up the part from a wrecker, but there was nothing at all around the hole that this came from, no vaccum hoses, holes, wires, nada...just this sensor screwed into the inlet manifold, at about the point where the downward section of the manifold curves back in toward the head. The wires ran back into the loom which is shared with the injectors.
    RA23
    1G-GZE
    Was it a Delco Camira or Bosch Camira?
    Its definately not the Delco air temp sensor one, but I've never looked closely at the bosch setup so it could be that.
    Delco one screwed into the 4th runner right near the head.
    +1 for it not being a camira air temp sensor (delco one anyway) ive purchased one about 2 weeks ago and they definitiely dont look like that
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    this is a usual camira/commonwhore type sensor...
    plastic cage with exposed element inside.
    for turbo aps, ppl sometimes put a dob od silicon to stop the element wavign around
    WA (Perth)
    I think it was a Bosch set-up but I don't know for sure.
    Thanks guys, I obviously don't have what I thought I had, its back to the wreckers for me.
    RA23
    1G-GZE
