Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: 1ggte into mx83
    Oct 2007
    Default 1ggte into mx83
    Hey guys,
    I would just like to know that if I was to buy a 1ggte gx81 half cut for my mx83, would it be a straight bolt in conversion like the jzx81 1jz?
    Default Re: 1ggte into mx83
    pretty much, crossmember's different but you can bolt in the GX81 crossmember.
    I got rid of the 1G from my GX81 GT to replace with a 1J, the 1G just didn't have enough torque for such a heavy car.
    get a 1j
    that is all
    The tractor Grease Monkey
    May 2007
    i dont think that the 1G is worth the effort spend the extra few dollars and get the 1J for sure
    Just wanted to pipe in and also suggest a 1jz...
    Unless you can supply some good reasons as to why 1g has piqued your interest?
    Oct 2007
    1jz would be sweet but not suitable for my budget and I really want a manual, the half cut that I am looking at is factory 5 speed and only a fraction of the price you would pay for a manual 1j.
    Is that a good enough reason
    May 2007
    nope lol nah it is i guess but u will find the engine lacking
    what gearbox you plannin on using?
    Oct 2007
    The gearbox is supplied in the half cut so probably a w58
    Apr 2007
    I agree with the others, once on boost the 1G is ok, but off boost you would wish you had the 7m still .. Going from a 3 litre to a 2 litre not the best idea ....
    My 2 cents worth ...
    Quote Originally Posted by Huz
    If they've got the tailshaft with the cut then it's an easy conversion. W58 has a different spline and slightly different length from memory. If you get the GX81 tailshaft front-half then you can bolt that to the MX83 rear section and get it balanced up.
    Or you can use a *X7* manual tailshaft front half.
    EP Grease Monkey
    go 1J, my 1G has biiger turbos and nothing down low. makes for good fuel economy though
    May 2007
    just out of interest how much is the 1G gonna cost you?
    Don't Trust Me I'm A Backyard Mechanic Jabtronic's Avatar
    Gold Coast, QLD
    Quote Originally Posted by AE_82
    1J has better fuel economy than 1G in a heavy car (in my opinion)
    The Fonz Grease Monkey rob_o's Avatar
    Huz... definitely go 1J. Save up the $$$ and do it right the first time. 1G is cheap but not suited to your car.
    1JZ Toyota Cressida Grande
  1. 1jz Jzx81 -> Mx83 Abs
    By mamba in forum Tech and Conversions
    Last Post: 21-11-2007, 07:28 PM
