Results 1 to 5 of 5
Thread: aw11 engine mounts
    Junior Member Backyard Mechanic KARNAGE's Avatar
    Default aw11 engine mounts
    Hi i am pretty sure the old engine mounts on the aw11 are starting to go. its the torque mounts i am unsure where to get a new set from does anyone know where to get some new ones from?
    Default Re: aw11 engine mounts
    if you can bare to not drive the car for a week.... go buy some sika flex 255 extra and remove the front and rear mounts (use stands to support engine). clean the rubber in the mounts with some prepsol and fill them with the sikaflex. leave for a week (i left mine for a week, wasnt useing car and wanted to make sure they were cured) to go off and put em back in.
    New Zealand
    yeah those mounts are notorious for failing in AW11s
    i used windscreen urethane for mine. its also possible to get them custom made with nolathane.
    just make sure that whatever you do, you do them in pairs. toyota engine mounts work as a pair
    AB
    what mounts are we talking about here? front and rear or left and right? front and rear can be found at twosrus.com. left and right..... ive only been able to source from toyota and of course they are way overpriced.
    Cheap tools take all the fun out of working on a car.
    My Rebuild and Conversion.... '81 Tercel 3A -> 4A-GE 20 Valve - ON HOLD.
    BAD ASS 1986 MR2 - Finally Moving forward.
    New Zealand
    the front and rears are the ones that fail most
    and "torque" suggests those ones
  1. MA70 --> JZA70 Conversion
  2. 89 4AGZE into '85 NA AW11 (engine mount problems) - SOLVED
    By Phildo in forum Tech and Conversions
    Last Post: 20-05-2007, 05:56 PM
  3. 4agze solid engine mounts, oil cooler/relocator kit questions
    Last Post: 03-10-2006, 05:49 AM
