the s/c gearbox mount is different to the n/a one so the gearbox will sit lower than the engine by about an inch or so which puts stress on the cv also at full travel the cv will hit the rear subframe
the rear torque mount on the s/c has 4 bolt holes 2 that go verticially into the chassis and 2 horizontially also from side on it shapes like this __| whereas the n/a mount and chassis only has 2 vertical bolt holes and is shaped like this __
However you can use either the n/a or s/c mounts for the front rear torque mounts and the engine mount however the gearbox mount will need modification to fit the n/a chassis or alternativley you can cut the whole chassis mount and battery tray out and graft a s/c one in
that engine side mount looks like there something isnt right there my gze engine and chassis mount bolted up exactly the same as the n/a engine mount
