Results 1 to 15 of 21
Thread: cam gear changes problem 4agte
    working hard Backyard Mechanic
    Default cam gear changes problem 4agte
    Hey guys i tried to put some bigport cams in my n/a lined it all up with TDC and cam pulley marking and replaced cams .. Now its all back together i havent touched the CAS as i didnt think you needed to , but after trying to crank it to start car wont fire up just only crank.. Question is how do i setup the CAS now with the crank and cam gears ????? as it was working 100% before i started Fvuking around with it.!
    Default Re: cam gear changes problem 4agte
    CAS out 180deg?
    if you changed exhaust cams.. then it would be very easy to bump the CAS gear when installing..
    what angle is it on timing light? (while bridging T? and E pins)
    umm i dont know aye , its just that i didnt mark the CAS before i did the cams idiot then i tried to crank car and the CAS is out with the crank and cams
    You need to re-install the cas. Not point doing half a job.
    Consult the 4age guide. Its very similar.
    Link: http://www.toymods.net/TechDocs/4age...4_timing_belt/
    I am not 100% compentant with the doing of the cams , reason i wanted to do it myself to learn , and being a non interferenace engine i thought ill give it a go .. I know nothing about CAS systems , ive got a picture of the car angle on TDC if this helps you guys to help me
    this is the possy of the CAS on TDC now
    http://img108.imageshack.us/img108/597/008ic8.jpg
    cant really tell shit from that.
    Did you look at the guide i sent you?
    DO it the exact same.
    Are you using an aftermarket ecu?
    nah mate stock 4agze ecu afm , il read the guide now
    set the engine to TDC, follow the guide posted above and that should fix it.
    The guide doesnt show anything about the CAS. ive did everything to get me this far... crank pulley is set to TDC and with the cam pulleys aligned, with the timiing cover markings
    My understanding was that i needed to adjust the CAS to suit the crank and cam pulleys.
    pull the cas out, there's a line in the housing near the shaft, and a mark on the gear on the end. Line the mark on the gear up with the line in the housing, install to the head.
    ok thats what i was after jp ur a legend mate...So there more then one way it can go in ? ill will be doing this tomorrow
    yes, it's easy to get it a tooth out and then it wont start...
    Here's the page from my engine manual:
    http://users.tpg.com.au/adsl0uxv/dist_install.jpg
    Ok so after take it out and religne in the proper grove then u set the ignition timing 10 degrees BTDC or dont i ?
  1. How to install an adjustable 1JZ cam gear in 1.5 hours
    By Mr DOHC in forum Tech and Conversions
    Last Post: 17-06-2012, 07:39 PM
  2. T50 to AZ6..... At the CNC....
    By oldeskewltoy in forum Tech and Conversions
    Last Post: 23-09-2011, 09:04 AM
  3. Replies: 2
    Last Post: 10-03-2009, 04:29 PM
  4. AE100 gear shift problem
    By sidta23 in forum Tech and Conversions
    Last Post: 22-02-2007, 06:44 AM
