Results 1 to 3 of 3
Thread: headlight problem
    "motoring enthusiast" Backyard Mechanic mideon_696's Avatar
    Default headlight problem
    Hi guys,
    i have a small (annoying) issue with my headlights.
    The normal, or low beam setting, is not working...
    what happens is this, i turn the knob to headlight on, no headlights come on, but curiously, the blue high beam indicator on the cluster comes on? the high-beam setting works as it should, just no normal beam operation.
    ive checked fuses, relay (swapped in my sisters), globes, visble wiring to back of headlights, and cant find shit.
    any ideas? i havent pulled apart the headlight operater as yet, wanted some possible ideas put forward first.
    Has anyone come accross a similar problem? Is the highbeam indicator coming on normal beam as a sort of "error code", telling me there be a problem, use high beam? or could it be that the wiring in the dash someplace is fucked?
    car is ae102
    No Signature.
    Default Re: headlight problem
    The headlights work by switching the ground after a relay is turned on. So common is powered, but either low, or high is grounded to select which lights will be powered. The 'blue indicator' light runs off the low beam ground side of the globe wiring so that when the hi beams are switched the low beams are effectively grounded through that light on your dash to make it turn on.
    Keep in mind that what stops the low beams fully lighting up is the fact that a better ground is provided through the hi beam so electricity prefers to travel that path being the easier of the two. Only a very small current travels through the blue light and low beam circuit.
    Maybe the wiring grounding the low beams is rooted? This wiring would be on your combo switch.
    Do the hi beams work when you push the stick forward and when you pull it back. By this i mean without low beams on just pull the stick back, then also try pushing it forward but this time have the low beams on.
    Edit: Also check the connectors on the back of the headlights for corrosion. The passenger side one will be more prone to it being located right near the battery.
    ahhh, i will check these things when i get a chance, hopefully tomorrow before work.
    makes total sense.
    thanks heaps for that leeroy, appreciate it mate
    yeah, the high beams work completely as they should
    No Signature.
  1. AE82 - Electric Problem
    By convert in forum Tech and Conversions
    Last Post: 25-02-2008, 12:30 AM
  2. Toymods Uploaded photos problem
    By JBs in forum Toymods Car Club Membership and Feedback
    Last Post: 26-11-2007, 04:18 AM
  3. Replies: 13
    Last Post: 07-09-2006, 04:57 PM
  4. CV joints problem with bigger engine (FWD)
    By progkamol in forum Tech and Conversions
    Last Post: 15-08-2006, 03:00 PM
  5. Gen2 3SGE Idling problem - Take 2
    By alliance_22 in forum Tech and Conversions
    Last Post: 21-12-2005, 07:54 AM
