Results 16 to 30 of 32
Thread: 2jzge modifications worth it ?
    Default Re: 2jzge modifications worth it ?
    i don't see why you'd bother bringing a 1uz to under 3L as the amount of cost invloved in doing so you could have spent on the cheaper 2jzge and get far more power anyway. Sure it'd be cool, but unless you have uber budgets it just ain't possible.
    If in doubt power out
    Junior Member Automotive Encyclopaedia Nim's Avatar
    Heh heh, I guess. But once you had the 1UZ down to 3L you could rev its tits off without having to worry about the bottom end.
    Anyway, yeah it's probably a silly suggestion. 2JZ-GE is awesome. Could you increase compression on a 2JZ by running a thinner head gasket and perhaps shaving the head? You might have issues with the valves hitting the piston if you run a lumpier cam with that setup though.
    Does anyone make ITBs for a 2JZ?
    Daily: DC2 Integra VTiR :: 96kw @7300rpm - 132nm @6300rpm
    Techno Toymods | Beninca Dyno Day Results 10/9/05 | GOR Cruise '06 | My Photography and Illustration
    looks at gianttomato and says he has some, ed was making a custom manifold for his 6 RB26 throttles which is now for sale.
    have considered the 1MZ, six throttle bodies and cams...
    Quote Originally Posted by ViPeR_NiPPleX
    mmm noice such a smooth motor as well, very quiet (much to do with the camry sound deadening) seems to lack low down torque though(manual 2002 camry touring kerb weight 1400kg), doesn't really hammer to above 4thousand+ rpm and loves to play tag with the 6.5krpm limiter.
    Can't really judge on the engine note what you can hear is alright but even at the redline the engine is quiet as once again sound deadening.
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Quote Originally Posted by Alchemist
    Waynes JZA61(Glen's old 2JZ MA61), already puts out 132RWKW with an exhaust and lightened flywheel, with the extractors Wayne is putting on it I reckon 140 isn't out of the question.
    I dont believe itbs raise the bar much on max power, more on responsiveness (and they sound sooo good), the remaining 8 rwKW Wayne is short on GT is probably due to the ecu I guess ??
    Quote Originally Posted by gianttomato
    OK. Now that I have convinced you guys that they're worth playing with, I'm going to be the devil's advocate and give you another choice (or two)....
    Nah, I think I like the 2jz, seems a bit simpler
    Quote Originally Posted by Enchanter
    On stock cams ITB's will not do much in the form of peak power as you said.
    Its all about A) the noise and B) the response.
    Give it some serious cams and you'll be needing those ITB's though.
    Penrith BC
    Quote Originally Posted by 7MA61
    ed has made a custom manifold for his 6 RB26 throttles which is now for sale.
    fixed.....
    ../delete/ban
    tech moderator
    Penrith BC
    ../delete/ban
    tech moderator
    that makes me all happy in my underpants.
    it's not for a gte per chance is it?
    aahh, who am I kidding, I have other mods to take priority.
    ps: Ed, I'll take those front coilovers. is it only the shock-tube that's bent? springs are still ok? any idea on spring rates? (as my rears are 8kg)
    Hehe alchemist must get it to stay ahead of wayne hehe do itt now, sorry for underestimating you ed i thought you would of stopped working on it once you started the 1uz project.
    I'd buy those ITB's off Ed in a flash, if that's all I had to change.....but. To get ITB's to work properly I'd need a brank spankin new ECU, tune said ECU, get intake piping fitted to go up with that bellmouth, possibly a fuel rail too? Trust me I'd love to do it, but just don't think it's feasible, but people feel free to correct me if people don't think it would cost me the earth. It'd be nice to have the intake on the opposite side of the engine to the Exhaust too
    Melbourne Victoria
    well i make 20 v throttles and can make 6 of any size that you may like ,on daves corona he has 6 x48mm throttles .i can make 45mm 48mm 50mm and 52mm that are still the same width as well as length as the std 20 v throttles are, my sets of 4 or 6 have all the linkages as well and you keep the injectors in the head as well like daves and im running vvti on my 3sge motor as well its all very interesting what you can do with it ,but you wont be able to run 540 thou cams in your 2jz maybe about 440 thou tops but that would be ok
    So if I get the 1uzquadcam.co.nz manifold, and 2 lots of 4x52mm throttles off you, it will all work?
    Melbourne Victoria
    yep no problem it will work ok
  1. 2JZGE into MX83
    By rvrolla in forum Tech and Conversions
    Last Post: 21-05-2007, 10:16 AM
  2. gti rolla, whats it worth?
    By jack_be_nimble in forum Tech and Conversions
    Last Post: 24-01-2006, 01:38 AM
