Results 1 to 10 of 10
Thread: Parts Req'd for 1JZ -> W58
    Nice..... Grease Monkey Rex_Kelway's Avatar
    Default Parts Req'd for 1JZ -> W58
    Hi lads,
    Rex be wanting to compile a complete list of the parts req'd to fit the W58 to a 1JZ/2JZ.
    So far He has in his mind:
    - N/A JZA80 2JZGE bellhousing
    - N/A JZA80 2JZGE flywheel
    - N/A JZA80 2JZGE clutch slave
    Is there anything in the front of the gearbox that is different and also required? IE Thrust bearing carrier, slider, fork etc?
    Are you limited to any particular W58?
    Am looking at ordering a few complete genuine conversion packages so need the complete list of parts that will be required.
    Thanks Muchly
    Rex
    Rex Kelway Sucks - Fabrication thread
    Rex Kelway - ABN: 41 267 379 001
    Fabrication, Manifolds and CAMS spec Roll-cages in SA...
    Default Re: Parts Req'd for 1JZ -> W58
    Dont bother with the slave, use an MA61 one, fits perfectly.
    Carrier, slider and fork are all interchangable betweeen any W58.
    EDIT: My 2JZGE>W58 is using the following
    • 2JZ-GE Flywheel
    • ARP Flywheel Bolts (4AGE)
    • 2JZ-GE Bellhousing
    • MA61 Clutch Slave
    Thats all you will need to convert, apart from a W58.
    P.s. you have a PM.
    Smile Re: Parts Req'd for 1JZ -> W58
    Hi how about a spiggot bearing???? . regards crownman 0412 711 481
    Crown parts for sale. Sydney
    Oh yeah, spigot bearing. NSK 6201.
    Junior Member Backyard Mechanic Hokey's Avatar
    THREAD DIG
    will this work on a w55/57 aswell? std carrier slider fork work with all the 2jz clutch parts?
    it should - W55/57/58 have the same bolt pattern on the front of the box (for attaching to the bellhousing).
    Sep 2008
    has any one ever priced a original bell housing for this conversion because i am considering getting one of those
    Quote Originally Posted by #rolla boy
    $300 - 500 depending on how much your local toyota parts dealer feels like screwing u
    User Conversion King
    NWA
    i think i did a quote up on all the parts when i was working at toyota.
    ill see if i can find the quote. the prices i got were at buying price haha
    hello
    Just did the conversion in my ra28
    $475 for a brand new bell housing
    $500 for a custom lightened flywheel
    $580 for an excedy button disc and 1000kg pressure plate
    $10 or something for the spigot bearing
    $20 - $30 for the new throwout bearing
    $40 for a set of ARP flywheel bolts
    all bolts together just nicely
    stidnam
  1. 3s rwd conversion parts, what else needed?
    Last Post: 11-01-2006, 07:43 AM
