Don't know about part numbers but my 18R-GEU had blue/green injectors.
i have two sets of injectors from two different 18rgeu manifolds
can anyone tell why the injectors have different numbers on them and if they ARE 18rgeu or from something else
numbers are 195500-0284 blue/green colour
195500-0474 grey colour
any information or where i can find out more would be appriciated
thanks Steve
(\__/)
(")_(") ITS ALIVE
Norbie!
www.norbie.net
I also have 2 sets, one blue 195500-0280, one grey-purple-ish 195500-1370.Originally Posted by MAD79R
Both 2 to 2.5 Ohm
Edwin
Projects: No project cars left ...
From what I can see the purple set ****1370 are 550cc from an Rx7.Originally Posted by RA23
the blue ***0280 may be the STD 18rgeu 210cc. I have a set but not here with me to see the numbers
MAD79R. if there dark grey and low imp, they sound like there 200cc from a 3sfe motor
since your no. is *****0474 I know that the ******0473's are 188cc so should't be much bigger.
EDIT. 195500 0474 - 2.1 ohm's 185cc 18lb/hr
These are based on that the injectors should be Nippon D type, which the number suggest.
my previous RA28, R.I.P is here.
http://forums.toymods.org.au/index.p...t=0#msg_651396
Current build here.http://www.toymods.net/forums/showthread.php?t=33512
i took my injectors off my 18rgeu manifold to have a look today. anyways, they are a grey colour and have 195500-0741 on them. they are definitely stamped ND. any ideas what they're from?
i'm not quite sure but they may be from a 4age 135cc. they seem small to me!
are they grey?
sorry just saw the colour above, they are grey..
the manifold i pulled those injectors out of was on the motor that i've described in the tractor thread......so i'm doubting they'd be small![]()
Just ckecked my spare 18rgeu injectors there teal/blue colour with 195500-0280?
At this stage I'm assuming you use a resistor box in your loom for the injectors, which then relates toOriginally Posted by old_school_jap1
(18rgeu's are top feed and low imp) these are all whith the EV1 connector ie square and the notch in the middle.
These are with no part numbers and grey
-dark grey 181cc and 199cc
-grey, 181cc
And as mentioned above the 135cc.
There are high imp in grey also,
When you say teal/blue, would that be sky blue?Originally Posted by ra_28
Colours and number may be the same, it comes down to the impedance that determines what injector you have.
As an example, I have red/brown top 195500-1350 in low imp, which are 460cc's
Codes and colours and CC's are the for the high imp, both from RX7's![]()
The difference by sight is the notch in the plug. A centre notch is low imp and an offset notch is high.
I'm no mechanic as such so please test my theories, I've just spent age's searching for the right one's for my application and this is the results.
See also toymods thread at http://www.toymods.net/forums/showthread.php?t=4809.
