also not to burst your bubble linden most of the new motors as in altezza have a oil restriction built into the head gasket so from 6mm into 2.5 mm for the head
fwiw i use to put a 2mm oil restriction plug into the back oil gallery on the gen 2 motor and was using a mechanical oil pressure guage on head and on the oil remoter filter there is something like a 30 psi difference on a std motor
also if you go up to the 5s block you will have to remote oil feed the vvti as the 3s altezza blocks are unique with the extra oil gallery to feed the vvti and also for the oil return on the cyl head back to the block as well
