Results 16 to 28 of 28
Thread: 18rg weird noise???
    Default Re: 18rg weird noise???
    Quote Originally Posted by allencr
    Center to center.
    If its properly resize its should stay exactly the same length. It will not change the center to center distance.
    Jeffro,
    Toyota didn't make them very accurately from the factory.
    Have a look at the small end holes and see how well centred they are!
    (\__/)
    (")_(")
    After thinking for an extra minute, do you resize the cap only?
    That is the only way that the rod would not get shorter, even if only by the smallest amount.
    There is an upside of shortening a rod, it moves the piston further away from the valves.
    (\__/)
    (")_(")
    Balloon Slayer Backyard Mechanic jimmmayyy's Avatar
    Apr 2007
    Lol, thats retarded! why do you think you need to get oversize bearings when the journals are machined?
    Jun 2007
    you could use the crank and rods from any 18R they will fit into the G Just need to get a engine machine shop swap the pistons over for you.
    When resizing a conrod they machine the same amount off the cap & the rod then bore the big end hole to the original centres, where not talking alot of material here so if the rod has had a fair bearing spin it's a bin job it's mianly to correct out of round.
    Go easy on the factory they have balance pads on the rods which are there for balancing purpose, so some rods look different to others because of different weights in the beams. So when building a tough engine thats why you look for a rod with the balancing pads nearly gone that tells you it's got max material in the beam, remembering the rods are balanced for total weight as well as end for end. Toyota has built it's reputation on reliablity so you would be a brave person to question their machining.
    Cheers Dave.
    ok i see what you are all getting at, would someone be able to write me a list of what i need to buy and get done?
    i have got 3 18r's sitting here what would it take to just swap ova the crank/rods, do i need to get it machined into the block?? or can i just pull one down to a basic block and bolt on the timing cover/dizzy/head and timing gear??
    thank you
    Jun 2007
    G pistons got to say with G head, so back to swapping pistons on rods sorry thats the only way.
    Cheers Dave.
    i have a set of 87mm forged 3tgte pistons will they fit??
    18r 18rg bore size is 88.50mm so no they wont fit sorry
    Quote Originally Posted by Steve M
    Rhetorical question.
    Quote Originally Posted by jimmmayyy
    Sorry, I don't get where machining journals has come into this discussion, did I miss something?
    Incidently, you can get ACL big end bearings for rods that have been resized larger than stock. Just thought that was interesting.
    Quote Originally Posted by TA23 Racer
    Have you ever compared a bunch of 18R-G rods to see their small end alignment?
    I had to combine almost four sets to find four rods that had holes close to the centre of the small end.
    Balancing 18R-G rod sets is always a good idea, I've got a collection with a weight range of upto about 40 grams difference throughout various generations (not including the 18R rods that were used in 18RGEU). One matching set from an 18RGU had a 10 gram range just within that set.
    (\__/)
    (")_(")
    ok this is all interesting now.
    so where can i buy a new set of conrods and pistons??
    Apr 2007
    It wasn't in relation to your post Steve_M, it was meant for allencr's post.
    No worries, jimmmayyy.
    lilcrash
    Argo (australian rod manufacturer) have made 18RG rods before, but they'd still be priced as custom.
    I'm sure the other rod manufacturers would also make a set for you, for a price.
    New pistons can be sourced from lots of places, some cheaper, some more expensive.
    There are two japanese websites that do them.
    Kameari Engine Works (toyhead auto is US supplier)
    & This mob:
    http://www.escort-jp.com/piston/toyota_c.html
    Arias can do custon forgies (they have the dome shape already worked out, just need sizes and compression heights etc.
    Brenton at fours'n'more in SA orders 18RG forgies from CP in the US.
    Toysport (if you can contact them) usually advertise them.
    (\__/)
    (")_(")
  1. Info: Emissions and Noise Testing
    By infotechplus in forum Tech and Conversions
    Last Post: 09-04-2007, 11:33 AM
  2. Replies: 47
    Last Post: 16-01-2006, 05:08 PM
  3. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
