Results 1 to 3 of 3
Thread: flycutting pistons
    Junior Member Grease Monkey Neverland's Avatar
    Nov 2007
    Default flycutting pistons
    Hi guys, just wondering how much it would be to fly cut pistons?
    3t/2tgeu hybrid. bsically it'll be 2tgeu with 3t crank and pistons.
    also will I need to bring the head along so they can match the valve angle to the piston?
    Thanks
    David
    Junior Member Grease Monkey Celica_73's Avatar
    Default Re: flycutting pistons
    From memory mine was about $150 to get them flycut. As the Guys around here don't know the spec on the Head i took mine in so they could measure the valve size and the amount of clearance required.
    The price will vary from place to place ofcoarse.
    Jason
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    often a piston with the original valve reliefs is a good sample to go by for angle.
    the head with cams installed or cam specs is a good measure for depth.
    the headgasket thickness and amount shaved off head or block also
    affects the valve clearance.
    just make sure the crown is thick enough to flycut down, depending what
    brand and type of pistons you have will determine how far you can flycut down
    to without leaving the reliefs too thin and weak.
  1. 8.0:1 4AGZE pistons and oil squirters
    By Bazooka in forum Tech and Conversions
    Last Post: 04-09-2007, 07:57 PM
  2. Where / What to get: 7MGTE pistons???
    By boxh34d in forum Tech and Conversions
    Last Post: 15-05-2007, 04:13 PM
  3. Light Vs heavy pistons (ie: ACL specs)
    Last Post: 14-04-2007, 09:27 AM
  4. comparing 2T and 2T-G standard pistons
    By w810sc in forum Tech and Conversions
    Last Post: 02-01-2007, 05:28 PM
  5. Pistons - Cast vs Forged vs Hypereutectic
    Last Post: 21-11-2006, 02:04 PM
