Results 16 to 30 of 39
Thread: z20/jza70 brake interchangability
    Default Re: z20/jza70 brake interchangability
    Sure do dude. But they can come from any late model A70 (JZA, MA) not jsut the MA.
    Malicious
    thanks mate + rep
    RA23 - Twincharged
    JZZ20 - Daily
    trying to get pics of these brackets so i can do a WTB.
    are these what they look like?
    RA23 - Twincharged
    JZZ20 - Daily
    Western Aus
    im a little iffy on NA MA70's too, i seem to have a fuzzy memory of shit brakes, but too much alcohol is running rampant through my system to clearly recall.
    Xistant
    Guest
    MA70 if it was non turbo or turbo had the larger dia brakes etc.
    Nah Kedders they are for mounting r32 4pots onto teh a70/z20 hubs.
    The 'braket' you need will look almost exactly like yours just longer 'legs'. I think atm your thinking of the whole caliper assembly as the caliper, which it actually isn't. When you jump under the car and have a look you will notice the 'claw' that comes over the top of the disc and holds the pad, this had a kind of short cylinder or buldge on the back of it. Thats the caliper. The part that that follows the caliper over the disc and loops back around, that is the 'bracket you need.
    When you go to change the pads there is a bolt and a peg that holds the caliper to the bracket, basically you undo the bolt and swivel the caliper of the disc. You will notice the 'bracket' will stay in place.
    Here is an exploded view from the a70 epc:
    http://www.cygnusx1.net/Supra/Librar...es/MCG261A.gif
    And for future reference here is a link to the TSRM and EPC for the a70 which shares almost all the same drive train components:
    I hope that helps!
    Malicious
    I hope that helps!
    Malicious
    thanks for the double! post mate, that explains it alot.
    Cant give you any more rep as I just reppd you!
    RA23 - Twincharged
    JZZ20 - Daily
    lol oops! No probs man, good luck in your search! I think you may end up having to buy a whole caliper assembly, but the up side is they are fairly cheap as they're is heaps of sup front cuts kickin round.
    Malicious
    KE25 legendary Backyard Mechanic Robbo's Avatar
    Jun 2006
    DB431, front's, Z20/ all A70.
    DB413, rear pads ,Z20, all A70
    !!! BAN LOW PERFORMANCE DRIVERS NOT HIGH PERFORMANCE CARS !!!
    私のトヨタはある従って速い均一死んだ人叫ぶ!
    im still confused here
    I have a guy whos willing to sell me the brackets and I think its the part indicated 43330.
    http://imajr.com/Original.aspx?Id=P1010056-1055333
    anyone?
    RA23 - Twincharged
    JZZ20 - Daily
    anyone?
    RA23 - Twincharged
    JZZ20 - Daily
    43330 is the lower ball joint. Thats not gonna help at all. Tho it is worth replacing about nowish in the cars life! lol
    Malicious
    theres +rep in it for you if you can tell me the part number either on that picture or the cygnus TSRM links, PLEASEEEEEEEEEEEEEEEEEEEEEE!
    RA23 - Twincharged
    JZZ20 - Daily
    47721 & 47722 RHS and LHS respectively.
    They aren't on the scna you have.
    Malicious
    By The Witzl in forum FAQ
  2. AE86 Brake Upgrade - Here is what I did
    By Sprinter in forum Tech and Conversions
    Last Post: 01-02-2007, 10:26 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
