Results 1 to 2 of 2
Thread: 1-KD/2-KD Boost pressures
    Jan 2008
    Default 1-KD/2-KD Boost pressures
    Hi all,
    Google didn't help. And I can't seem to find anything in relation to what the turb's are on them plus what pressures they are running FROM Factory
    I did notice on the the Parado though that the exhaust housing is HUGE comparing to the HiAce for instances but the intake housing is still the same size. Would this be due to one being mainly used for Taxi's *Hiace* against the other as a large 4wd?!?
    thanks in advance
    Simon!
    wa
    Default Re: 1-KD/2-KD Boost pressures
    I think you will find that the turbo will not be the limiting factor in performance between the hiace and the prado i am quite sure they also run different fuel pressures also
    One is also a 3 lt the other is a 2.5lt
    Cant confirm now but im also sure they run about 10psi from factory but i will find out for sure if you want.
  1. boost creeping issue..
    By renxun in forum Tech and Conversions
    Last Post: 11-03-2007, 08:32 AM
  2. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  3. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  4. Boost Leak Tester
  5. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
