roller bearing CHRA's are available new, you may need to machine the housings slightly to suit though.
or just buy a new turbo?
I just tore down another T25, i now have 3 bare centers (whats there technical name?)
Each of them came out with brass bushings, is there anyway to convert them to bearings?
Just need to find a good shaft/exaust wheel and i will have boost!!
Also how does one lock off the std wastegate, Do people have good experience using KKR gear, i want to support forum sponsors and otomoto hvae been good in the past
Originally Posted by WHITCHY
Nothing but good reports so far...Originally Posted by merc-blue
http://www.toymods.net/forums/showthread.php?t=19649
Random question, is the dump flange on a T25, T25G and T28 the same?
Not always...
Last edited by twentyEight; 14-04-2008 at 06:35 AM. Reason: Stupid twentyEight giving mis-information!
nope, not all the same.
there are 4 and 5 bolt designs aswell as 2 different 5 bolt patterns (nothing an 8mm round file cant fix though)
linden
I retract my comment...
I've only seen the 5 bolt design, and they were exactly the same...
yeah most are 5 bolt but there are 2 different patterns on them depending on what you buy.
1 stud moved 3mm for some ghey reason that really fuckd with my head one day.
linden
have seen the wgates welded shut to the exh housing, just a couple tack welds,
but yeah, turbos are so cheap why spend $$$ when you can buy new better one for the same $$$ or less.
I know that the GTR T28s are different, guess i should have thought of that and been more specific - will a dump pipe for a ca18det fit a stock s13/s14 t25g / t28?Originally Posted by The Real Roadrunner
Thanks gents![]()
Yeah i never did much reseach into what a turbo costs, i always assumed it was 3-5 grand, but a turbo the size/spec im looking is under 1grand. new turbo time!
by filing a hole it will, have fun if its a stainless flange.Originally Posted by Bananaman
I've had a full exhaust made for my car, but this dump and 3" front pipe came with my motor, don't need it, need to know who i can sell it toOriginally Posted by The Real Roadrunner
Sorry for the thread hijack![]()
