Results 1 to 5 of 5
Thread: 4agze tacho not working
    Junior Member Grease Monkey Intense's Avatar
    Default 4agze tacho not working
    I bought a kouki jdm guage cluster for my ae86 today. Before I had a adm guage cluster in it and I followed a PDF guide on how to get the tacho to work, and surprisingly enough it did work. All you needed to do was replace 3 parts on the circuit board and it would go.
    Now knowing the new cluster is just normal I swapped the modded circuit board from my old cluster with the one in the new cluster. But it won't work.
    This is the stock circuit board from the kouki cluster
    Here's the guide I followed to get the old cluster working
    http://members.iinet.net.au/~awcabren/ae86gzetacho.pdf
    Any ideas why this one won't work? When I turn the ignition on the tacho levels to 0 but when I start the car nothing.
    Sa22c Series 1 rx7, 12a extend port, 900rwkw @ 93,320 rpm sold
    Ra65 celica hatch, 22re with 2.25" exhaust, 500Nm @ 27rpm sold
    Ae86, 4agze, 170Takumi Powers @ 11,000 rpm
    Default Re: 4agze tacho not working
    if the board worked in the old cluster, it should work in the new cluster if the cluster harness pinout is the same between the two.
    I put together that PDF guide and I've used it on a whole bunch of AE86 and AE71 tacho drive boards with sucess.
    I'm gonna give it a shot with the kouki cluster circuit bored and swap it all back in. Fingers crossed
    ok swapped the components onto the kouki circuit board and the same thing. Tacho won't work. It moves a little when u turn the ignition on but then just stays at zero.
    so have you checked to make sure the harness pinout is the same between the Aus AE86 and the JDM harness. Wouldn't suprise me if you had to repin it.
  1. Tacho tech
    By Hen in forum Tech and Conversions
    Last Post: 04-08-2009, 04:10 PM
  2. AE92 tacho not working with MT LT10s
    By BoostBoy in forum Tech and Conversions
    Last Post: 27-03-2007, 07:26 PM
  3. 20V TPS & 4AGZE CAS -> MoTeC (check the working of Rex...)
    By Rex_Kelway in forum Tech and Conversions
    Last Post: 08-03-2007, 02:58 PM
  4. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 09:36 AM
  5. RA40 tacho & aftermarket ECUs - anyone had trouble?
    Last Post: 29-11-2006, 03:59 PM
