OK, on your timer.
Red - 12v constant power
Black - Ground
Green - Ignition 1 (Primary). This senses the ignition being turned off. Connect to the ignition barrel wire that has power with ignition on and whilst cranking only!
Blue - Ignition 2 (Secondry, sometimes needed for thermo fan etc). This is hooked to your second ignition wire, the one that has power on but not whilst cranking. Some cars don't have an IGN 2, so hook it to your accessory or nothing at all.
Your thin white wire may need to be connected to your handbrake switch. You can just ground this wire at a testing stage to see if it works.
Now on your vehicle:
Not being a Hachi man myself, i'm not 100% here but this may still help.
White or White/Red - 12v Constant power
Blue - Accessory supply
Black/Yellow - Ignition Primary
Black/White - Starter Solenoid (Not used)
Check these with a test light first! I'm only going off common Toyota ignition barrels from the 80's here and I don't want to see you destroy car/timer from what i've stated.
