hey guys i just bought this blitz Fatt DC full auto turbo timer but i dont have the instructions and i cant find them on the net just wondering if anyone could help me out.
and if anyone has installed one on a GZ20 if they could walk me through it that would be great!!
cheers Ryan
the first link didnt work dude
cheers for the second link, i was wondering how it went in there
usually you get a short bt of loom with two plugs that goes between you ignition switch loom and the rest.. so you just unplug and plug.. except for speed and handbrake sensor
yeah thats if you have the harness but i dont have the harness so im just gonna hard wire them in
try advan performance in sydney. I brought my greddy turbo timer loom there for $20.
other then that its only 3 main wires. you dont need to connect the speed and handbrake cable. you'll find that some auto timers are useless when it comes to so called "auto" function ie 15-20 second cool down after 110km/1BAR boost highway run.
better to set it manually from 30s-1minute max imo.
yeah thanks but i know wat the red wire is obviously the power but i dont know wat the blue and green wire is can anyone help??
Cheers Ryan
on the apexi one if im not mistaken its been a while since i installed mine but there should be red black obviously, 12+ and -. blue and green connect to the ignition wires, most cars have 2 ignition wires that keep the car running, i conncted one the timer and it would not work but connect the 2nd wire (which should be called ign continue) to the blue i think it is if not swap the 2 and one way will work no damage can be done.
i used the blitz wiring diagram to wire the apexi so i think its pretty much universal
what color wires do you have and how many. there should be 4
i have two black 1 red 1 green 1 blue and a purple for the handbrake
SoarerTT didn't you check out the links?
DIAGRAM
FATT Ign. Colors
Purple --- Hand Brake
Orange --- Speed Sensor
White --- Shift Lock (Auto)
Red --- 12 Volt WHITE/RED
Blue --- Accessory BLUE
Green --- Ign. "on" RED
yeah i did but the colours on the ignition loom in my car are all browns and blacks so thats where im getting confused i no wat the turbo timer wires are i ust dont know which wires on the loom i tap into
pull off your steering cover and look at the ig switch as it should be written next to each wire, falling that use a multimeter...
Noisy Diff and Gearbox Club of Pine Riversand you thought your car was loudThe Soarer brought to you by the letter TT
yeah thanks for your help guys i ended up using my test light and found out which wire is which and its working beautifully cheers again
