Results 16 to 25 of 25
Thread: 4AG starts, runs and dies condition (almost there) EDIT : IT RUNS NOW!
    Default Re: 4AG starts, runs and dies condition (almost there) EDIT : RUNS ON AEROSTART :)
    Just another thought, as you say from a delco background, I used to use the camria throttle body that had a stepper motor in it. In order to get the system to work properly with out the speed sensor I had to block off the idle control ports(of the stepper motor) that the speed sensor controls(through the stepper motor). Don't know if this applies here.
    T'ville, QLD
    perhaps check for air leaks esp big ones... thats why my 20v didnt run
    2T out 4A in....
    Victoria, BC
    I'd suggest checking your source power for the ECU. IE IG SW on the computer. Upon switching the ignition to ON and then also while your are cranking the engine, I suspect that you have 12V in the ignition switch ON position, and you loose that when you switch the ignition switch to START, so as soon as you let go of the key, it will fire or run for a second, then die. You should have 12V to that pin when you switch to the ON position, and when you are in the START position.
    This happened to Julian Edgar when he installed an RB20 into his old Skyline. He thought he was getting 12V for the ECU when he was cranking the engine, but the point where he took this 12V powe for the ECU, looses 12V when switched to the cranking position.
    Nilezy
    90 MX83 Cressida Grande - 1JZGTE VVTi, A340LE, PWR FMIC, driven everyday SOLD
    01 Y61 GU 'glued back together' ZD30 grenade, 5 inch lift, ARB front and rear air lockers, Taipan XP exhaust, Safari Dtronic
    85 S3 RX7 - Dual Axial Flux motors & controllers, traction and stability programs, 1Farad cap. & LiPo batt, 60km range, 0-100 km 3.2 secs & 200 km/h top speed.....
    Hoppers Crossing
    3jcelica............interesting........not sure i'd want to be disabled teh IAC.....would make normal starts a bugger
    i'm using the std 4AG 100kw ECU here, so, no delco here
    skiddz.........been caught out with that before on my old 2T. so yeah, in check
    nilezy.........thats been playing in my head since this condition started and will check first chance i get today
    (no time spent diagnosing yesterday, daughters 1st birthday which i spent driving 300km trying to get her to sleep (she is sick at the moment)
    Hoppers Crossing
    Cool Re: 4AG starts, runs and dies condition (almost there) EDIT : RUNS ON AEROSTART :)
    nilezy........power fine.
    reckon i've got it
    (video to come)
    basically during a start event - only one injector actually spraying fuel
    i had another set of injectors. same same
    tried the one good injector on other plugs - worked
    so in short, my injectors are knackered. which explains why it runs on aerostart
    Hoppers Crossing
    Default Re: 4AG starts, runs and dies condition (almost there) EDIT : IT RUNS NOW!
    it runs. yay
    in short - i pulled the injector baskets out of the injectors and soaked them in fuel.
    one injector is still dead but the other 3 are working just fine. so runs on 3 cylinders (still pretty bloody smoothe mind you go figure)
    BIG thanks to all who have input here and helped out - i really appreciate your help!
    Hoppers Crossing
    video of the first start
    http://www.ae92.info/images/4age1stStart.3gp
    (need quicktime yo)
    Good to hear its running mate. Injector cleaning and servicing is well worth the money. Mine ran ok but while i had them on the flow bench i soon realized how much shit was blocking them up.
    Youtubed version http://www.youtube.com/watch?v=aQgCHn2Fp0M
    Hoppers Crossing
    thanks des
    an update : its missing on number one cylinder
    i have spark and i have (too much) fuel as the plug is wet and i do have spark (which fvcking hurts) at the end of the lead
    remarkebly it runs really well on 3 cylinders. my missus just reminded me it is very noisy - you get that with no exhaust - exhaust is exiting @ the cat convertor
    hopefully get the injectors done tommorrow.
    Hoppers Crossing
    thanks to B&M Fuel Systems in Richmond VIC i now have a set of fully reconditioned 4AGE 100kw fuel injectors
    end result : my car runs perfectly.
    YAY
  1. 1JZ-GTE Soarer runs for 7 sec, then dies - where to start?
    By PT1 in forum Tech and Conversions
    Last Post: 22-03-2007, 03:02 PM
