Results 16 to 28 of 28
Thread: Cleaning injectors, 1JZ-GTE. Advice please.
    Default Re: Cleaning injectors, 1JZ-GTE. Advice please.
    Quote Originally Posted by HAVABEER
    hey jorrs where abouts did you get them done at?
    and i assumed you pulled them out of the car?
    nah the car was in workshop gettin the headgasket retensioned so while it was there i got them to get injectors cleaned, they sent it away to a place they use in town who has a flow bench, and cos hes a good bloke he just charged me wat it cost him to do it, but yeh as i said im sorry i didnt do it earlier
    Corona loving Grease Monkey TTMX83's Avatar
    i think it comes down to what solvents they use, how "vigorous" the ultrasonic bath is, and if they are being pulsed with fluid runnign thru them at the same time...
    some places seem dodgy, others never have probs.... fidn one that is recommended by a few people and go with them
    Thanks for that. I was concerned about the procedure. I'll just get them flow tested and find the best 6.
    I think the main issue with side feed injectors is the fact that not many shops have a flow machine to test them after they have been ultrasonicaly cleaned. In addition, they seem to be more difficult to clean then standard top feed injectors anyway so that only compounds the problem.
    If you get then cleaned AND flowed there shouldn't an issue.
    Quote Originally Posted by TTMX83
    i'm not saying that cleaning per se is bad, just that sometimes the results are not so good, but some shops seem to always do well, so it's important to check up that they do a good job first
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    Cleaning is worthwhile but unless you get them flow checked you have missed half the point.
    If you have several to choose from select the ones that have the closest flow rates - this will give you the best results.
    Quote Originally Posted by Grant
    That's right. The shop that did mine couldn't do a spray test because they were side feed. Seems pretty stupid to me as I think there would be a fair few cars with side feed injectors. Maybe not as many but still a fair few.
    QUICKEST 1JZ'S IN OZ
    Even something as common as a Tarago has side feed injectors!
    OK, another question. What should I take note of when reinstalling them?? I have a new set of o-rings and dampers/insulators coming. Given the hassle it was of getting them out, I really don't want to have to do it again.
    Cheers Brad.
    1) Replace all the o-rings
    2) Check for leaks
    3) Double check for leaks
    Assuming it's similar to the 1G, I usually put the dampeners into the retainer spots in the head, then I clip the injectors into the rail (make sure you use some rubber grease as to not damage the new o-rings). I then press the rail into the dampeners making sure that all the injectors are seated correctly. Then do as Starfire said, check for leaks...then do it again
    Junior Member Domestic Engineer mic*'s Avatar
    Quote Originally Posted by Starfire
    Second that ^^^^
    CLOSEST not HIGHEST. Precision is more important. Also abnormally high flow is just as good a sign that an injector is rooted as low flow. Its just a lot more common for them to gunk up (low) than to corode (high) or fail other ways.
    meh...
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    I had mine cleaned and flow tested when I still had the motor in the front cut, came back one was a little dodgy, so I bought another and all is well.
    Cost me $20 each - dropped them off on the tuesday arvo, got a call on Wednesday morning saying one was dodge, gave him the go ahead to replace it and they were ready with flow rates on Wednesday arvo (even got the dodge one back and not charged for that test - just the 6 good ones)
    i had my plenum off my 1J for a reason, and figured it couldnt hurt to check my injectors, fuel rail, return regulator ect ect... with all the injectors out i noticed ALL of the o-rings were mangled, they seemed quite thin and hard aswell. i carby cleaned all the injectors and fitted new fatter o-rings and everything is tip top. there doesn't seem to be any difference performance wise, and i mixed up the injectors for good fun.
    I didn't even think to have them professionally cleaned or 'flowed' as there was no problem with them in the beginning.
  1. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
  2. 1JZ into EA Falcon
    By bezza05 in forum Tech and Conversions
    Last Post: 27-01-2006, 11:18 PM
  3. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 10:09 AM
  4. 1jz emanage ultimate
    By atomic rob in forum Tech and Conversions
    Last Post: 13-01-2006, 06:18 PM
  5. mechanical specs for 4agze injectors
    Last Post: 04-01-2006, 01:05 AM
