Results 1 to 8 of 8
Thread: 3SGTE not happy
    Western Aus
    Default 3SGTE not happy
    hey all, got a mate with a problem, ive never seen anything like it..
    if you start the car, you need to hold the throttle slightly open, otherwise it just coughs and farts, when it starts, you can rev it freely.
    then, when you set it back down to idle, it idles fine.
    after idling for a few secs, you can crank the throttle FULLY open, and it doesnt increase revs, cough, fart, stutter, nothing.
    it just continues idling.
    originally i thought it might be a sock or something in the intake, althogh it doesnt fully explain it...
    i cant check exhaust or what its like under boost as the cars running, but not rolling.
    any idea as to what i should check?
    it used to run properly after i did the wiring, started without problems, and runs fine, but there was a problem with the cam gears (aftermarket jobbies, apparently needed a spacer behind em?) and this only happened after the motor was taken out to fix.
    its obviously not timing, so maybe a problem with the TPS, or something left unplugged?
    Elmo.
    Default Re: 3SGTE not happy
    Elmo.
    Theres your starting point... recheck every bit of wiring. Does sound like electrical fault, and either TPS, MAP or AFM... or perhaps its another TLA I havent yet listed
    Oxy sensor would blow soot, but run normally, knock sensor would allow it to rev up, temp sensor would put it in limp mode, but it would rev up.
    Yeah, sounds like TPS actually, cause you can rev it when it is cold and the cold start injector is inserting the extra required fuel, but when it warms up, you cant rev it as it is only putting in enough fuel for idling.
    Opening throttle "FULLY" and not picking up revs isnt possible, check that the trottle is actually moving more than 1 degree. Ie, the throttle linkage is properly working/connected, as it sounds like all your problems are around the throttle area.
    I dont know if u can actually do this with all the EFI and what-not, but try open the throttle with your finger (im not talking about the cable or wheel, but the brass butterfly its self).
    Its not fly by wire is it??
    AFM / MAP sensor not plugged in or faulty?? sounds like throttle opens up, and it's not taking in any air..
    and drive by wire in a 3S motor? *meh* eldar's not into champagne and garden parties
    Check the wires going to the ISCV, I've seen something similar before which ended up being that
    Is it AFM or map sensor?
    I am the sun
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    What model 3s is it, i'd say it is the afm or a loose ic pipe. My mr2 did the same thing when the ic pipe popped off. And 5m/7mge's do the same thing when there afm is unplugged or stuffed.
    1994 GZX90 Mark II 1GZ-FE V12
    Agree - AFM most likely. Check wiring, and check the flap is moving. (assuming its an earlier 3S)
    And just for the hell of it, i'd try running it without the air filter first. It might be that simple.
    EDIT: Check wiring continuity. Im pretty sure, that if the clip is off the AFM altogether there is no power to the fuel pump relay in which case it shouldnt run (for long) at all.
    meh...
  1. 3sgte Limits???
    By Douglas Black in forum Tech and Conversions
    Last Post: 30-11-2013, 10:33 PM
  2. To 3sgte or not to 3sgte
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 23-03-2006, 04:23 PM
  3. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 06:55 AM
  4. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 03:03 PM
  5. 3sge - 3sgte CAS - interchangable?
    By Steve M in forum Tech and Conversions
    Last Post: 20-12-2005, 08:15 PM
