Results 1 to 9 of 9
Thread: Diff ratios
    vic
    Default Diff ratios
    A question for the maths guru,s. If my tailshaft is doing 1000rpm
    with a 3.26 diff ratio with the standard
    supra wheels 225/50/16 ( I think thats the standard supra tyre for 16 in)
    how much extra RPM is the tailshaft going to do if i use a 3.58 diff with 205/65/15,s ( these shoud be bigger than the supra tyres).
    Ps , i did find norbies search on the diff ratio calculator but i cant seem to open it
    Dave
    vic
    Default Re: Diff ratios
    So far i have found a few ratio calculators on google, but whats other suggestions.
    Dave
    The size of your wheels/tyres are not going to make any difference to the speed of the tailshaft or diff.
    That is, a ratio of X:1 will spin at X:1 ratio whether you have 205, 265 or no wheels.
    I think what you are after is the difference in circumference between the tyres, so you can work out how much more (or less) rolling distance each revolution of the tye makes, then use this on your rpm calculations to determine to road speed?
    seeyuzz
    river
    vic
    Yeah thats what im trying to say , i,ll get a few outside circumferances on a couple of tyres first.
    Dave
    Ignoreth my previous drivel
    http://akb.norbie.net/Public/Gearing.aspx
    This will answer all your questions.
    vic
    I like the % way .
    Thanks wilbo
    Dave
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    225/50 R16 -> 1983.6mm Circumference
    205/65 R15 -> 2034.2mm Circumference
    +2.55% difference in tyres.
    -8.38% in diff (If I got it right?)
    So about -5.83% in overall ratio, so you will do 5.83% more engine revs at any given speed?
    no you multiply, not add
    225/50R16 diameter is 2*225*50%+16*25.4=631.4mm
    205/65R15 is 2*205*65+15*25.4=647.5mm
    ratio is 631.4/647.5=0.975=
    -2.5% tailshaft speed at const speed
    ratio of circumference is the same
    diff ratios are 3.58/3.26=1.098 =
    +9.8%
    (100-2.5)%*(100+9.8)%=0.975*1.098= 1.07=
    +7.0%
    tailshaft speed [and therefore engine] will be 7% higher at same speed
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
    Quote Originally Posted by ta23-mbzq-nnr
    +9.8%
    +7.0%
    Yep this is right, ignore my drivel!
    Happy to be corrected
  1. Toyota Manual Gearboxes and their Ratios (W, R, V, K, T, P)
    Last Post: 05-09-2012, 02:48 PM
  2. Hilux diff ratios.
    By wheel rim in forum Tech and Conversions
    Last Post: 30-07-2007, 07:01 PM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
