Results 16 to 22 of 22
Thread: Turbo 1uz - Turbo oil feed and return
    Penrith BC
    Default Re: Turbo 1uz - Turbo oil feed and return
    i cant tell you how many times ive suggested to david (lextreme) that teflon tape on oil line fittings is a retarded idea... but, well...
    dont use teflon tpae on oil systems fittings
    ../delete/ban
    tech moderator
    but the tape is supposed to seal against "gas" leaks and "gas" comes from oil so...
    (edit: i'm kidding.. don't use teflon tape)
    Forum Sponsor Conversion King
    Dec 2006
    why not use a proper pipe sealer? ie the non hardening stuff.
    I did think that teflon was bad..
    Facebook | LinkedIn
    Junior Member
    Jan 2008
    What sort of sump do you have? (Front, Mid or rear?) I ask this cos the front sump version has a nice little inlet with bolt holes around it on the drivers side to return the oil. Dont know how to send pics, but I can go out and take a photo if you want? (I dont have a turbo, but I did have to plug the hole up)
    Cheers.
    Front.
    I know exactly what you mean. That's the oil level sender unit, which I'm not going to use..
    So I could use that for my return, my concern is that it's on the other side of the engine bay from where the turbo will be, so I'm cautious of using it. I'll probably end up using it though.
    Facebook | LinkedIn
    Dec 2006
    weld a -10 male fitting on the sump in the position you want and job done, then you dont have to worry about tightening clamps and other such nasty things.
  1. late 97 on hilux 3rz turbo conversion walk through
    By BeRad in forum Engine & Driveline Conversions
    Last Post: 07-01-2011, 07:10 AM
  2. 3t-c oil feed + return for turbo
    Last Post: 30-08-2006, 02:58 PM
  3. ta22 feed and return fuel line sizes
    By shelldrake in forum Tech and Conversions
    Last Post: 08-02-2006, 10:40 PM
