Results 1 to 15 of 22
Thread: Turbo 1uz - Turbo oil feed and return
    Default Turbo 1uz - Turbo oil feed and return
    Hi guys,
    All those who have turbo 1uz's, where have they taken oil feeds from and fed the oil return back to?
    I was thinking
    FEED: Split off the oil filter position.
    RETURN: Drill into the upper portion of the sump and plug something in there.
    Is that the right spot to put them?
    Facebook | LinkedIn
    Default Re: Turbo 1uz - Turbo oil feed and return
    yup,
    you can fit a T piece into the oil pressure switch which is on the oil filter block/housing, and return just to a fitting welded to the sump,
    i hope this is for the 23?
    Yeah, it is for the 23.
    I was wondering about more specifics though. like exactly WHERE in the sump casting it was put, and how high up, etc..
    Facebook | LinkedIn
    get onto lextreme.com theres quite a few good write up on the 1uz, and
    pure porn for some
    HERE'S THE LINKY YOU WANT, http://www.lextreme.com/oil.html
    you can put the return pretty much anywhere you want, just aslong as the turbo sits higher then the oil level line, to prevent pooling in the bearings. (if you get what i mean....)
    Yeah, cool. Thanks for the link.
    I know about the level of the oil return, the concern was more; at what point in the sump should it go.
    That link is good.
    Facebook | LinkedIn
    return should be below windage tray.. and toward front of engine, since most oil flow will be during accel... why did they choose directly under the crank pulley?
    that big arsed t-piece hanging off the oil filter mount looks like a motor waiting to lunch itself
    sure a shirt soft line, to a T piece hard mounted to a bracket would be a better and less fatigue prone option?
    I can't uderstand why they put it under the crank pulley either!
    Plus, I would put it in the Steel Pan, not the Alloy Sump! (Which would be below the windage tray as OC suggested)
    ([][][]II--LT--II[][][])
    Yes, but if it's in the steel pan, it'll be at roughly the same level as the oil, and could cause pooling.
    EDIT: And why below the windage tray? The 1g oil return from the factory was above it.
    Facebook | LinkedIn
    I believe the pooling occurs when the Turbo sits below the oil level, not the oil return...
    Forum Sponsor Conversion King
    Dec 2006
    depending on turbo placement is it possible just to run the return back in where the oil level sender is/was?
    don't use a T into the block and have a sender hanging off it, ive seen 5 of them snap so far and one of them cost the owner an engine + a turbo.
    do as OC suggested and run a 4" section of braid out to the T and have it mounted on a bracket, also if your using a brass T make sure that the oil galleries are big enough for the oil supply as most of them are only around 1.6mm id, should be at least 3mm.
    linden
    Dec 2006
    pooling will only occur on 2 occasions, 1 your return hose doesn't have a constant fall to it or 2 the return goes in below oil level, shouldn't happen for any other reason unless you have a severe windage or blowby issue.
    linden
    I believed wrong...
    Cool. Thanks Linden.
    So basically, use the hole where the oil level sender is (I'm not gonna use it anyway) and run braided line out of the oil pressure sender hole, to a t-piece mounted solid against something THEN run the feed off that.
    Also, what happened to that return PM linden? ;-)
    Facebook | LinkedIn
    Dec 2006
    simply missinformed (that was in response to 28)
    buried in my inbox, ill dig thru tonight and reply to it.
    linde
  1. late 97 on hilux 3rz turbo conversion walk through
    By BeRad in forum Engine & Driveline Conversions
    Last Post: 07-01-2011, 07:10 AM
  2. 3t-c oil feed + return for turbo
    Last Post: 30-08-2006, 02:58 PM
  3. ta22 feed and return fuel line sizes
    By shelldrake in forum Tech and Conversions
    Last Post: 08-02-2006, 10:40 PM
