Results 16 to 17 of 17
Thread: Modified Tail Shafts, how to measure up?
    Default Re: Modified Tail Shaft's, how to measure up?
    If you are asking me that q - I was using the stock tailshaft as a reference - Provided you don't bottom out at any point and there is still as close to the original amount of tailshaft over theoutput shaft from gbox, you would assume this to be acceptable - But perhaps ring a driveshaft shop for a more accurate tolerance for specific applications.
    Forum Sponsor Conversion King
    Default Re: Modified Tail Shafts, how to measure up?
    you should have the shaft set up so it has 15mm minimum that it can slide further into the box but if it IRS it wont matter as mauch do to the fact that the diff wont move.
    linden
  1. How to fix your ST162 tail lights when they stop working
    By mikie_121 in forum Tech and Conversions
    Last Post: 08-04-2008, 03:24 PM
  2. Balance Shafts in 5S
    By RWDboy in forum Tech and Conversions
    Last Post: 16-05-2006, 01:53 PM
  3. how to make two shafts rotate together... ???
    Last Post: 23-03-2006, 05:24 PM
