OK WELL,
A)
The easiest way to measure it up is center-center of the unis,
Each time i have had to build a tail shaft its from scrach so i ordered the unis, gearbox shaft and diff flange, assembled the unis into there respective ends, put the respective ends into the gearbox and bolted to the diff, measure the distance
Make soure your trailing arms for the diff are parrallell to the ground when you measure it all depending on how the trailing arms are setup it can affect the length,
Also allow for the slip join (im assuming gearbox ouput) is not all the way in and has appropriate engagement
B)
You can sorce unis and the tail shaft ends, you will probly be able to get the diff flange new aswell, the gearbox output may be hard to get new.
Hope this helps
 Modified Tail Shafts, how to measure up?
