interior fan not working? If it's never worked since the 3sge went in I think I know the problem
Hey everyone
What i am chasing is a wiring diagram for a 1988 st162 ST model.
Not the engine or ecu wiring diagram but the other stuff specifically the interior fan and AC.
Also this car has had a 3sge put in it. Im reasonably sure that wouldn't effect the fan but if im wrong let me know!
Cerby
I am the sun
yeah i bought the car from another fella and it hasn't worked since i got it. But im pretty sure i need the fan to pass rego so yeah i need to fix it! My dads an electrician so we were planning on tracing the problem tomorrow hence needing wiring diagram.
But lets assume its never worked and you can tell me what i need to fix![]()
Cerby
one of the circuit breakers in the passenger side kick panel will have no power (cb 2 I think)
run power to the in side of it from the battery (put a fuse in close to the battery), don't worry the fan won't run when the car is off this way, the CB is switched with the ignition
otherwise power comes into it from a wire in the engine bay, near the air con idle up vsv there should be a plug for it... if your old man is good with a multimeter just see if you get continuity between it and the circuit breaker, and put power to that wire
I am the sun
cool sounds good we are having a go at it tomorrow and we'll see!!
edit: i'd give you rep but it says i need to spread some around before repping you again even though i don't think i've repped you before!! However i will not argue with the all powerful omniscient mega being that is the computer!
