Results 16 to 20 of 20
Thread: 1J water flow through engine
    Thumbs up Re: 1J water flow through engine
    Quote Originally Posted by manny
    How do you suggest 1jz-ge and 2jz-ge engines hold together without an oil cooler and said valve from the factory?
    good question. i just went out to my shed i have a N/ A 2j and im looking at the oil system and theres no cooler. i unscrewed the oil filter and no relief valve like you say.
    hmmmm i wonder if this valve is even here? but all hydraulic filter systems should have a filter blockage bypass relif valve.......
    i then thought maybe its in the filter so i hack sawed it in half and in the bottom of this filter is your engine saving relif valve!!!!!!!!!!!!.
    now this filter is a "union" brand filter, C-171M part no
    does the 2jzgte filter have this valve?
    i use a z418 in my 1.5jz. i dont know if the z418 has this valve built in???????????.
    does anyone have an old filter they can cut open and check?(i dont wat to pull mine off as it only new and ive already chucked the old one out)
    so thanks very much manny,
    they say you learn somthin new everyday and tobay i can say i learnt that some(maybe all????) spin on filters will bypass themselves when blocked
    let me now edit that statment i made earlier about "making sure you keep the oil cooler) "if you use a filter that has a built in internal relief valve you can now throw that cooler away!!!!!!!!!!!!!
    Default Re: 1J water flow through engine
    al167, pretty sure all conventional engine oil filters will have inbuilt bypass valves
    Junior Member Backyard Mechanic manny's Avatar
    Quote Originally Posted by al167
    The OEM filters certainly sure do and I would be vey surprised if even the cheapest and nastiest of aftermarket filters didn't.
    Here are a few Toyota and TRD filters dismantled for reference.
    http://www.mkiv.com/techarticles/par...ter/index.html
    http://www.mkiv.com/techarticles/par...ers/index.html
    The EPC lists the valve you're refering to as an oil cooler relief valve
    GSE20 IS250 - daily
    one of those filters (the V8 lexus one) looks like its made from beef jerky!
    1GGTE POWER 1st year Apprentice Mahindra1GGTE's Avatar
    Jan 2008
    New Zealand
    anyone got a diagram or anything like that for 1ggte ? as i am also not running a heater and all that stuff !!
    77" Mahindra WW2 Style Jeep - 1GGTE - Expected 300hp atw
  1. water injection pre turbo
    By project_x in forum Tech and Conversions
    Last Post: 28-03-2008, 07:41 AM
  2. MA70 --> JZA70 Conversion
  3. my masochist engine swap... 3S to RWD
    By Roman in forum Engine & Driveline Conversions
    Last Post: 10-04-2007, 10:22 PM
  4. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Engine & Driveline Conversions
    Last Post: 27-03-2007, 05:08 AM
