Results 1 to 15 of 22
Thread: 1GGTE Single Turbo Conversion ? Wanting To Make 220rwkw !
    1GGTE POWER 1st year Apprentice Mahindra1GGTE's Avatar
    Jan 2008
    New Zealand
    Default 1GGTE Single Turbo Conversion ? Wanting To Make 220rwkw !
    hey guys i have a 1ggte engine in my 1977 mahindra jeep same as a 1942 willys jeep WW2 Shape
    i am wanting around 220rwkw how can i go about getting this ?
    i would like to run factory ecu
    any help would be great
    here are some pictures for you guys to look at !
    77" Mahindra WW2 Style Jeep - 1GGTE - Expected 300hp atw
    Forum Sponsor Conversion King
    Default Re: 1GGTE Single Turbo Conversion ? Wanting To Make 220rwkw !
    220rwkw with a factory ecu = not a chance.
    if you add an exede or similar piggyback (probly link over there) then yes it would be possible but your factory injectors will need to be upgraded and if your running a piggyback you may as well run a 1uz afm.
    a GT3071 would get you there or even a GT2871 with a .86rear housing if you so choose.
    budget in mind?
    linden
    PS that thing is cool
    Jan 2008
    New Zealand
    budget is around 1k at the moment
    i am looking at using a :
    Super T70 V Band turbocharger Brand New $500
    the specs on it are:
    Turbine housing A/R .84
    Compressor housing A/R .70
    Oil Cooled shaft
    Wheels 64.5mm and 60.5mm
    or a
    TD04E Turbo Brand New $445
    Specs:
    SPECS:
    .57 COMPRESSOR WHEEL TRIM
    .50 A/R COMPRESSOR
    .63 A/R TURBINE
    Whats The Max Boost i Can Run 20psi ? 22psi ? and max boost on stock ecu but aftermarket turbo ?
    max power that i could make on stock ecu, stock injectors but aftermarket turbo
    i will look into a aftermaket ecu later on but at the moment want to get everything else sorted and making the most power i can with the stock ecu
    Jan 2008
    New Zealand
    im running a 5.38:1 Diff, Bring On 12second 1/4 Miles
    first - that is an awesome idea! love it.
    second, on stock management and stock injectors, you are not going to get 220rwkw.
    with your new turbo, you'll also need front mount ic, big exhaust, etc, and these mods combined will get you a good hit of power. Is there a special reason why 220rwkw is the number for you?
    Jan 2008
    New Zealand
    Quote Originally Posted by Draven
    Thanks Alot
    on stock management and stock injectors, you are not going to get 220rwkw. with your new turbo, you'll also need front mount ic, big exhaust, etc, and these mods combined will get you a good hit of power. Is there a special reason why 220rwkw is the number for you?
    220rwkw is Just a Number i Wanted the Magic Number i guess, would settle for 200rwkw on stock ecu though.
    front mount inter-cooler, 2.5" full mandrel bent exhaust. etc is all in the books that will be done no mater what.
    How do those Mines Ecu Work if i got one of them will that allow me to get 220rwkw + maybe 250rwkw max ?
    my next goal is to do a 12sec 1/4 mile the jeep weighs around 950kg with a 5.38:1 diff, 3speed gear box with the final gear of 1:1 . if anyone has any ideas on how much power i will need to do a 12sec 1/4 mile please discuss
    12 could be possible with 200rwkw but it would need to get a damn good 60' time ie slicks and a big launch.
    high 190s can be done on a gen3 ecu but not sure what yours is.
    there is no boost cut on a 1g as they run a maf sensor therefore it will only have a airflow cut, how high is it? not sure but rod couldn't run over 195rwkw without hitting his.
    i dont recommend the mines ecu as you dont know what the tune in it is like until you purchase it and put it on the dyno to then find it is incorrect.
    super t70 is definately big enough to do the job but it will be laggy and wont like the factory ecu much.
    linden
    Jan 2008
    New Zealand
    my engine and ecu i believe is gen 3,
    is a custom single turbo manifold a must or will a y pipe to join up the twin turbo manifold into a single turbo work ? and will that support 200rwkw ?
    and do i need a bov ? and i don't want it for the wank factor, as i hear alot of compressor surge when i let of the gas at high revs ?
    you could quite easily do the Ypipe,
    i made 195 rwkw with standard gen2 ecu/inj/afm with a custom exh mani and a gt30/71r
    i have no idea how the AF ratios were as it was only a power run that didnt sow the AF's
    but 200rwkw will be pushing everything to its limits.
    Jan 2008
    New Zealand
    how much boost ?
    12psi, external gate.
    Jan 2008
    New Zealand
    yes but most people run around 15psi would that get me to 200rwkw ? and i saw once ( cant find the site agian ) a guy running 20psi with a larger turbo stock ecu and internals and everything and he used a y pipe is well and if i remember correctly he mad something like 260-285rwkw
    theres EMP? on here, he has a ke30 corolla with a 1ggte, has made 280rwkw usuing a Y pipe,
    theres no way in hell the factory injectors would flow enough, at 100% duty cycle they flowed 380cc's you could possibly get a lil more out of them with a higher rail pressure, (but why risk it?)
    you can use 7MGTE 440cc inj, they are a direct replacement for the stockos, (cheap also)
    ultimately you are going to need something other than stock to control it.
    realistically a SAFE power output would be around the 180rwkw with factory controls
    i got a t70 with y pipe 440cc injectors microtech and 24psi
    just my budget way
    KE38 - 2TG
    MS65 - 1UZ
    I ran a 13.1 with 170 rwkw. A willys with over 200rwkw would be a death sentence
  1. Aristo-T70 single turbo. *pics*
    By jzk25 in forum Engine & Driveline Conversions
    Last Post: 16-12-2007, 11:03 AM
  2. Boost Leak Tester
