Results 1 to 6 of 6
Thread: 4age into corona
    mycarona Grease Monkey mycarona's Avatar
    Nov 2007
    Thumbs up 4age into corona
    hi my son is think about putting a 4age in his 86 corona only problem is will it fit please help
    Default Re: 4age into corona
    is this a RT142 corona?
    it will fit but it wont go any better, the corona comes standard with a 2.4 litre engine and you want to put in a 1.6 litre engine
    granted the 4A-GE is a great engine there are better engines to put in
    if you want to keep it non-turbo consider a 1G-GE which is a 2 litre 6cylinder that would fit well
    other options are 3S-GE (2ltr 4cyl) but will require some work to make it RWD
    then its the larger 6cylinders from there 1JZ-GE, 2JZ-GE and 7M-GE all are big and require some shoehorning
    i suppose the question is what are your final plans for the car, does it have to be non-turbo and how much money have you got to spend?
    Not sure how conversion savvy you guys are but I suggest any of the Camry V6s in RWD format.
    Check for legality etc.
    Nov 2007
    or sr20
    pretty easy. just new cross member and mounts and gearbox and g/box mounts and tailshaft. and some other bits !!
    Nov 2007
    thanks people
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    They actually made Coronas with 4age as an option way back when. Why? But it means it can be done and if you should find a at141 halfcut, it'll be bolt in, haha.
    Good luck on your quest
  1. ST171 Corona running celica GT4 hardware?
    By cylinderhead in forum Tech and Conversions
    Last Post: 14-07-2006, 11:43 AM
  2. 4age tech question?
    By pro-16t in forum Tech and Conversions
    Last Post: 30-04-2006, 10:42 PM
  3. big port 4age comparisom
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 03-04-2006, 08:12 PM
  4. 4age engine mounts
    By duff_boy in forum Tech and Conversions
    Last Post: 03-03-2006, 12:35 AM
