Results 1 to 6 of 6
Thread: Help!!! 1JZ no sparks or CAS signal
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    Default Help!!! 1JZ no sparks or CAS signal
    Any help much appreciated, trying to get my 1JZ Soarer finished in time for next weekend. Only problem is I have no sparks or anything from the Cam angle sensors or Crank angle sensors. I assume this is the route of the problem.
    Any ideas, I'm thinking it might be a dodgy earth lead or similar???
    I've got fuel & stuff, all the relays are working etc. Will I get a fault code off the ECU with this issue? if so whats the output at the ecu/diagnosis ports/wires?
    Its a swapped in 1JZ by the way so not factory fit, ran all last year & not been moved for 4 months so that maybe the root of the issue
    Dec
    Sliding his D1 Soarer around the UK
    Junior Member Grease Monkey 3BarSuperstar's Avatar
    Nov 2007
    Default Re: Help!!! 1JZ no sparks or CAS signal
    Can you get your hands on another computer? How do you know your not getting a signal from the crank or cam sensors?
    Dorset
    Quote Originally Posted by 3BarSuperstar
    Does the ecu output anything to the CAS? I get a resistance at the sensor but nothing else. It would be a 3 wire (one to ground at the unit) so I assume it'll feed a voltage through it - nothing happening though
    with a multi meter, check your getting a good 12V reading at the ignition module, and then with a led test light see if your getting a signal pulse from the ecm
    regards dales
    also make sure that your signal wire from your ignition module to your tacho is getting grounded and there fore making the signal go to earth, on cranking is your tacho jumping at all, is your injectors clicking
    Dorset
    Ahahah
    Only getting 5v at the black/oarnge wire to the ignitor unit which I thought was odd, but being 5v appeared maybe normal?. Perhaps thats the issue?
    I assume its a switched earth from the ecu to the igniters?
  1. mx83 1jz auto issue
    By jeffro in forum Tech and Conversions
    Last Post: 16-02-2014, 08:47 PM
  2. Toyota diganostic error code, where can i find them?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 19-03-2008, 12:42 PM
  3. Fault Codes
    By Duk in forum Tech and Conversions
    Last Post: 24-07-2007, 08:42 PM
  4. 4agze fault codes & diagnosis + Pulley
    By Poggy in forum Tech and Conversions
    Last Post: 01-05-2007, 10:11 AM
