Results 16 to 26 of 26
Thread: Smallport block + bigport head = Interferance engine ?
    Default Re: Smallport block + bigport = Interferance engine ?
    Just make sure they are using something more sophisticated than a dremel. Ive seen a dodgy bros use a dremel before.
    http://www.roadandtrack.net.au/
    Thats the mob thats doing my machining and engine work from now on, Haven't heard a single bad rumour about them and a good mate works there. UMR engines did awesome work just they are very expensive and don't specialize in 4A engines but road and track has ALOT more experience. They arnt dodgy
    Ive heard of people doing it but i all ways thought it was dodgy and only back yard blokes did it but it seems i was under the wrong impression.
    Are the Toda/HKS timing belts any better than say a gates racing timing belt or a genuine Toyota item ?
    Default Re: Smallport block + bigport head = Interferance engine ?
    feral: add a couple of snapped belts, ive done one, adam did one, erin did one. all before the factory service schedule.
    why not get the valve reliefs cut out if your worried? easiest way IMO
    linden
    So got any more info about this procedure ?
    oregon
    possible causes for a belt to break/strip prior to mileage.... TIME... rubber begins to deteriorate immediately after it is manufactured. Frequently timing belts have time intervals as well as mileage ones......
    cutting reliefs is easy on forged pistons(even with a dremel....not by me.... but), cutting deeper releifs on a cast piston...... not something I'd recommend
    Hoppers Crossing
    des. like linden said, flycutting is fine to pistons. its not dodgy.
    talk to terry @ road and track he is a good guy and knows his stuff - he's been around 4AGE's long enough to know them well mate.
    if at all in doubt, plasticine and dummy assy the head/block and then rotate by hand to check for clearance matey.
    Junior Member 1st year Apprentice q.c.autosports's Avatar
    Feb 2008
    California
    Modeling clay and mock up assembly will take the guessing game out. You'll be safe with .060 valve to piston clearance.
    I've personally never seen a belt snap, but I've seen a crank pulley fail and spit the woodruff key out. This was on a smallport motor with a shaved bigport head, he was running stock lift cams so there was no damage...
    Junior Member Backyard Mechanic Dimitri's Avatar
    yes shearing the keyway is a pretty common fault.
    also one of my cams jumped a tooth the other day, had me scratching my head for a while.
    Quote Originally Posted by Dimitri
    IMO if the crank pulley bolt is torqued correctly this shouldnt happen.
    (a lick of loctite shaft stuff on the crank pulley before slipping it on helps too).
    Quote Originally Posted by TooF
    too much tension on the belt maybe...
    Quote Originally Posted by feral4mr2
    On this one, the top of the keyway cracked and literally popped out. The bolt was still tight...
  1. MA70 --> JZA70 Conversion
  2. Engineers Cert. Question.
    By Mk3_supra in forum Tech and Conversions
    Last Post: 07-03-2007, 10:49 PM
