Results 1 to 14 of 14
Thread: Converting MZ21 ABS to MZ20 Standard Brakes.
    BHGBTDT Domestic Engineer kemicalx's Avatar
    Default Converting MZ21 ABS to MZ20 Standard Brakes.
    Hi all,
    I'm currently contemplating ripping out all the ABS gear in my MZ21 and am just wondering if anyone knows if there are any diferences between the ABS master cylinder/proportining valve and the non ABS one?
    Should i just be able to replace the brake lines running from the master cylinder to the ABS module with lines off a non ABS mz20/ma70?
    Cheers All,
    Ash.
    Default Re: Converting MZ21 ABS to MZ20 Standard Brakes.
    Judging by the TSRM, the master cylinder looks the same, but can anyone confirm this?
    To swap the lines over will require the engine out of the car, if you wish to do this that is perfect for a factory look.
    Other option is to remove the ABS unit and get a T piece for the front lines to connect up with and the rear line can be bent back down the adapter on the firewall.
    Thanks mate,
    Engine is out of the car at present anyway, but that T piece idea sounds like an easier option than chasing down a new set of lines. Thanks for the heads up.
    Quote Originally Posted by kemicalx
    Thanks mate,
    Go to the wreckers and pinch one off a diff. Easiest option.
    Forum Sponsor Conversion King
    hehe, isn't that what i used on yours teh dangah?
    either that or just buy one from an auto parts store, most decent places will have them in stock.
    linden
    linden
    Sorry, should have read, go to lindens workshop and pinch one off a diff.
    Do you mind taking a snap of the lines for reference sake, i took out the module this morning and it looks pretty straight forward. But picture would help.
    Cheers.
    Junior Member Grease Monkey Bored?'s Avatar
    I have the ABS removed on my mz20. A new T piece will cost next to nothing from any brake shop. I can also confirm that the standard brake lines will work.
    i wish i was a Domestic Engineer JU57CE's Avatar
    hey Ash,
    did you end up doing this?
    and did it work?
    Current MZ21 soarer...
    EVERYONE CLICKY -
    http://www.facebook.com/event.php?eid=109989081509
    Beer Fueled Domestic Engineer doobs's Avatar
    I know for sure he has disconnected the ABS unit, and the car is running fine now with out it, I beleve he has done what is outlined in this tread
    ah ok. yeah mine is stuffed, and i figure its easier to remove it than replace it..
    EVERYONE CLICKY -
    Yep it's pretty straight forward, though replacing the lines wouldlook a lot neater.
    haha its got a 7m.. so neatless is not going to happen anytime soon! lol
    EVERYONE CLICKY -
    By The Witzl in forum FAQ
  2. mz20 standard brake size?
    By Intense in forum Tech and Conversions
    Last Post: 06-02-2008, 08:17 AM
  3. ke 15 sprinter questions.
    By bomber in forum Tech and Conversions
    Last Post: 30-12-2006, 05:31 PM
