Results 1 to 13 of 13
Thread: spray paint help needed
    Default spray paint help needed
    we primed the rolla with primer putty and it came off the gun sweet, used a 2mm needed.
    next we try to put some paint on, using a 1.4mm needle and its terrible. no matter how we adjust it the paint comes out really thin with mostly air coming out.
    the primer wasnt thinned, the paint is thinned with 1.5 thinners to 1 paint as per the tin. the gun was properly cleaned out after the primer but when painting it just doesnt want to work. when you turn the air pressure down on the gun and close it then open it again momentarily it works really well with good flow but then goes shit again.
    any ideas?
    Default Re: spray paint help needed
    is it a gravity feed gun or a paint pot?
    As I only have experience with gravity feed guns because I have just about finished spraying my car. Try changing the gun filter as most primer putty's clog them up real bad. If that fails, I need to know what brand of paint you are using, brand of gun, etc, etc.
    It's a gravity gun. We are using acrylic paint.
    the gun is a wallwick. no filter in the gun
    there should be a filter between the pot and the gun. Inside the threaded section. I am sure wallwick's have them?
    Im pretty good with a paint brush and I have a mini roller lying around somewhere....at least that way you will actually get some track time this year!!
    Forum Member 1st year Apprentice mrta22's Avatar
    Feb 2008
    queensland
    hey what brand of paint did u use and how did u measure the volume of the mixture, what kind of gun did u use and what grade of sand paper did u rub the putty with hmb
    Junior Member Grease Monkey Casino Kid's Avatar
    hav u unblockd the hole in the top of the lid/cap,cuz if this is blockd the paint will not flow out the gun proply
    1989 MX83 Cressida- stock 1JZGTE /king springs/jic's/17's/jzx81 front end.. 248.9rwhp
    1988 GX81 Chaser, stock..........
    2001 hilux-Street racer/Drifter/Track king/ Daily driver
    Apr 2007
    If there doesn't seem to be enough paint coming out with the smaller needle, then try the larger one again. I've never found that needle size makes a great amount of difference.. i usually just use the 2mm needle. Check that the fluid cap air vanes aren;t blocked, and the paint inlet also.
    Is the needle pulling back fully? I had a similar problem just a few days ago.. the needle had separated where the trigger step is.
    there were filters in the kit but never thought about them much, i for some reason assumed they went in the air inlet on the gun, but i will definately put one in.
    i will also check the hole in the lid, didnt even think about that and it sounds like a likely cause considering how small it is.
    ok just went in the garage and the lid breather was infact blocked. cleaned it out with a pin and now its ready to go, also put the filter in the top of the gun reay for use.
    was gonna paint today but looks like im going out for a bbq and some halo
    thanks for the help guys, if anyone wants to see how it goes check the SR thread in my sig
    south austraila
    Quote Originally Posted by EVOSTi
    just read the thread...
    & was going to say try the breather.... But you have found it...
    Project: '82, GA61 XX
  1. ulladulla charger's roof needs a lick of paint - help needed
    By gerald1 in forum Tech and Conversions
    Last Post: 28-12-2006, 04:27 PM
  2. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 02:09 PM
