Results 16 to 19 of 19
Thread: 1G-GE & 1G-GTE Starter Motor Part Numbers
    Default Re: 1G-GE & 1G-GTE Starter Motor Part Numbers
    The 3T GTE came with a reduction starter motor - the 3T did not. Yes you can use whichever starter motor with the, but in one case, depending on which starter and which bell housing (sorry cannot recall which) you need to use through bolt and nut. ie: the bell housing didn't have the clearance to feed the bolt into the starter.
    HTH
    Low Down Style Domestic Engineer Johnzoku's Avatar
    queensland
    very sorry to dig up old thread.. X2
    but am i reading correct that a 2T/3T bellhousing will fit a 1g motor to a W5X box?
    Quote Originally Posted by xcedricx
    This is correct IF you have the 2T/3T to W5X bellhousing - ie it is no good getting the T50 2TG bellhousing and thinking that it will bolt up. One other thing too - the 1G bell housings are more readily available than the 2T/3T.
    south austraila
    Quote Originally Posted by ae86drift
    Could someone with an EPC or anyone who knows these part number please advise.
    Are there differences between the two? Or between year models?
    Part numbers as asked for..
    1G-EU, 1G-GExx. # 28100-15040... rated at 1.0kw
    3AU. # 28100-15040... rated at 1.0kw.. ( found in AE70E,AE85,AA60,AT140..)
    3AU/4AU. # 28100-15060...
    3T-GTE. # 26142-27020... rated at 0.8kw
    3T-GTE. reduction drive. #28100-27030... rated at 1.0kw
    3T. # 28100-27060... rated at 1.0kw.. ( found in TA62.. carina.. )
    4AC. Manual. # 28100-15060.. ( found in AE71 )
    4AC. Auto. # 28100-15031.. ( found in AE71 )
    Project: '82, GA61 XX
  1. 4AGE reduction starter clarified
    Last Post: 28-11-2011, 08:09 PM
  2. how to boost power to starter
    By warrior in forum Tech and Conversions
    Last Post: 20-02-2006, 04:16 PM
  3. 3K starter pinion center distance from crank center?
    By 510rob in forum Tech and Conversions
    Last Post: 14-01-2006, 08:34 PM
  4. Tips on replacing the starter motor in an RA65
    By azmodai in forum Tech and Conversions
    Last Post: 22-12-2005, 05:12 PM
  5. 20v starter motor
    By Selk in forum Tech and Conversions
    Last Post: 19-12-2005, 08:08 PM
