Results 1 to 3 of 3
Thread: 4AG cam cards????
    oregon
    Default 4AG cam cards????
    I've been doing some research for my smallport build, and I'm looking for cam cards - camshaft specifications. I have Web's, I'm looking for Tomei's Poncam, HKS's 256, 264, and 272, as well as all the sub 9mm Toda 256, 264, 272 offerings. Anyone got their cam cards left?? Scan and post them...!!!!
    Web has theirs available(I copied the ones I'm interested in....their 4AF grind is the same as the 4AG grind)
    Frontyarding Grease Monkey Mitchee's Avatar
    Default Re: 4AG cam cards????
    Wade 1465a. 277deg.
    Code:
                           W A D E   C A M S H A F T S    P  T Y   L T D
                                        A.B.N 62 004 544 996
               Phone (03)9568 0333   Fax (03) 9568 2633   Email  [email protected]
               Profile          Actuation             Make/Model           R/Ratio
              1465A            Bucket          Toyota Twin Cam 4AGE 1600   In1 Ex 1
               Cam Lift   Duration    Duration   Valve   Valve   Cam Lift   Phase
                           Adv          @050      Clr     Lift      tdc      <0
      Intake     0.349      277        224      0.01     0.339     6.992    110
      Exhaust    0.349      277        224      0.01     0.339     0.048
                                 Timing               Timing
                                   Adv                 @050
                              Open      Close     Open      Close
               Exhaust        70        27        45        -1
               Intake         30        67        5.5       38.5
                                    57                  4
                              Deg Over-lap        Deg Over-lap
                   For Bucket type Engines,  Lift @ TDC is measured with Zero Valve Clearance
           WARNING: Cam followers must have good surface finish and correct radius.
           Lubricate well, avoid high RPM for the first 2 hours.
           To avoid coil-binding, after the tappets are set, check that the valve-
           spring can be compressed at least an extra .050" after full lift has
           been achieved. This will stop the valve springs from binding
    Current daily: AE92 SX Hatch
    Previous rides: ST141 CSX, SA63, RT142 Avante, AE82 Twincam, AE82 GZE.
    Coming Soon: Jza80 Supra... One day...
    AE82 Owners Club - http://www.ae82.net
    oregon
    Quote Originally Posted by Mitchee
    Wade 1465a. 277deg.
    VERY cool... thank you! Also thank you kpcruz (from hachiroku.net) for the current HKS offerings!!!
  1. 4ag into ma70 chassis
    By mdcmotorsports in forum Tech and Conversions
    Last Post: 01-12-2007, 12:02 PM
