 Originally Posted by
Joshstix
				The Gen2 and Gen3 stock cams will fit into either head.  The Gen1 cams will only work in a Gen1.
The gen3 cam differences are 0.5mm more lift and ~4degrees more duration on the intake.  Plus the stock timing of the exhaust cam is 6 degrees retarded compared to the Gen 2 cam, but the profile is unchanged at least in duration and lift, rates may not be identicle.
Aftermarket cams that state they are for the Gen3 will not fit in the majority of Gen2 heads as the casting was changed for Gen3 to give more clearance for the cam lobe to the outer parts of the casting.
