Results 1 to 15 of 17
Thread: Gen 3 3s-gte cams into Gen 2 3s-gte??
    W.A.
    Default Gen 3 3s-gte cams into Gen 2 3s-gte??
    Got hold of a set of gen 3 3s-gte cams out of an sw20 today, wondering if they would be a worthwhile upgrade into my gen 2 3s-gte sw20 motor.
    Any1 know if this is A. possible as a straight swap and B. whether it is an upgrade or not?
    I havent actually measured em up or anything yet and was hoping someone might already know before i start trying to figure it out for myself.
    Matty
    Forum Sponsor Conversion King
    Default Re: Gen 3 3s-gte cams into Gen 2 3s-gte??
    they have more lift and duration but not by heaps.
    not sure if straight fit, you would have to measure the journal and lobe centres as well as sizes.
    if the base circle is bigger or smaller by 1mm forget about it and get some 264's as the time+$$$ you spend setting them up wont be worth it in the long run imho.
    linden
    Ps if you put up some measurements i can Xreference them to a gen2
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    I asked a similar question a while ago a didn't get a definitive answer, mine was gen 1 cams into gen 2 as I had some 264deg gen 1's. from what I have heard gen 1 and 3 are interchangeable but gen 2 uses larger buckets and the cam lobes are a lot bigger but the bearing points are the same. So maybe I could make it work with much thicker shims
    Oh yeah gen 2 base circle is a fair bit bigger!
    W.A.
    Cheers guys i'l get some measurements up tonight, sounding like its not gunna be a straight fit though.
    I hadent planned on putiing cams in the motor anyway but i got these at the right price so thought it might be worth a try.
    Tasmania
    ive put a set in a gen2 head, the major thing is if they foul on the casting of the head i think. Im my case it was fine with plenty of clearance.
    1973 TA22
    The Gen2 and Gen3 stock cams will fit into either head. The Gen1 cams will only work in a Gen1.
    The gen3 cam differences are 0.5mm more lift and ~4degrees more duration on the intake. Plus the stock timing of the exhaust cam is 6 degrees retarded compared to the Gen 2 cam, but the profile is unchanged at least in duration and lift, rates may not be identicle.
    Aftermarket cams that state they are for the Gen3 will not fit in the majority of Gen2 heads as the casting was changed for Gen3 to give more clearance for the cam lobe to the outer parts of the casting.
    W.A.
    Quote Originally Posted by Joshstix
    So in this instance do you think that using just the gen 3 inlet cam in my gen 2 motor i may be slighty better off than the standard cam? and then leave the exhaust cam standard?
    Matty
    To tell the truth I think the 6 degrees of retard on the exhaust cam is more useful than the intake cam. However I haven't done any back to back testing, this is just based off the results I have seen from using adjustable gears with the stock cams.
    W.A.
    Hmm ok then thats interesting, maybe i should order a set of cam gears too........hmmm dunno.
    So would the extra .5mm lift and tad more duration be any better on the intake side at all? or would it risk being worse off?
    Tasmania
    will give a small gain but a gain is a gain, if you have them put them in.
    and you will gain uber cool points because your mod list will state "gen 3 cams"
    1973 TA22
    W.A.
    hahah its all about the mod list!!!
    Should i put both in then?
    Tasmania
    yep put both in.
    1973 TA22
    Junior Member Chief Engine Builder Classique71's Avatar
    they freed up my old gen2 a little - it was worttyh the effort to get that particular head ready for the HKS cams that will be going now into y gen3 ..
    if you have them and have time to do a shim under conversion - put them in !
    Saphira - ST205 Celica GT-FOUR Group A NZ No:1/4
    "Mongrel Garage - back on Aussie soil! "
    W.A.
    surely i dont NEED to do a shim under conversion for an extra half a millimetre lift thou ay?
  1. Toymods and CAMS Affiliation
    By twentyEight in forum Toymods Car Club Membership and Feedback
    Last Post: 19-11-2007, 03:11 PM
  2. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  3. Whats the diference between these 7m cams?
    Last Post: 18-01-2006, 03:15 PM
