Results 1 to 6 of 6
Thread: 1G-FE - Option ?upgrade ? Info ? spec , limit ?
    thailand
    Default 1G-FE - Option ?upgrade ? Info ? spec , limit ?
    MY celica is running on a 1G-FE
    i know so little about this Engine .. can someone sled osme light to this for me ..
    WHat can i Do to make this engine perform better , What kinda Option do i have in term of Upgrade , custom , ect ect .. Is
    Thanks you ..
    Osix
    Default Re: 1G-FE - Option ?upgrade ? Info ? spec , limit ?
    The best advice I can offer would be to replace it with a 1GGTE or 1GGZE which are the "sport head" forced induction variants of the 1G motor.
    the GTE is twin turbocharged good for nearly 150rwkw on stock turbos and the GZE is super charged (dont know modification specs sorry)
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Can it and put in a 1g-gte
    Facebook | LinkedIn
    Ditto. I wouldn't bother with a 1GFE, for less effort you could put in a 1GGE and make more power out of the box. Failing that, you could put in a 1GGZE or 1GGTE and make a HEAP more power out of the box.
    thailand
    I try looking for a 1G-FE engine here but is not easy to buy - that why why i am looking for Option for This engine .. .
    osix
    Unfortunately, your options for the 1GFE are going to be even more limited. As for not being able to find the engines readily, if you can't find one there, have it imported, it'd be the easiest option.
    Last Post: 29-02-2016, 12:30 PM
